586,108 active members*
3,084 visitors online*
Results 1 to 5 of 5
    Feb 2010
    24
    850SX Arc problem
    When trying to run just a simple arc program like this I am getting an error msg 0006 End Point Off Circle, end point in circular interpolation off more than .0100 inch on line N06 any help would be great. The machine is a Sabre 1250 with Acramatic 850SX control
    Thanks, Joe
    N01G70G00G90G40T237H00M06
    N02G00X.4425Y0.S2500M03
    N03G00Z.25
    N04Z.1
    N05G01Z-.5F10.3
    N06G03X-.4425I0.J0.
    N07X.4425I0.J0.
    N08G00Z.25
    N09M02
    Jan 2010
    Talking Arc Program?
    What is it you are trying to do?
    Cut an arc or a circle?
    From what I see in your program, you have no movement to do either one.
    Your X position is not moving anywhere.
    You have no I or J movement either.
    You have positioned the machine to X.4425 Y0. Z.25 , you then moved in Z down to Z -.5 but then you are asking to move CCW to the same X you positioned to and you have no Y position noted. This ends up with no movement.
    Normally, the X position would stay the same if you have movement indicated by a J amount for which you would be moving off center in the Y direction hence Y would not stay at 0 in your program but be a number to make a circle.
    A arc would usually be made with both a I & J movement.
    (nuts)
    Feb 2008
    586
    IIRC, I and J are absolute arc center coordinates on an 850SX. On a Fanuc, it would have been relative to the arc start point. I'd try two things. First, I'd call another G03 on line N07. Then I'd call a G01 and not G00 on the next line. Have you tried:
    N03G00Z.25
    N04Z.1
    N05G01Z-.5F10.3
    N06G03X.4425Y0.I0.J0.
    (MSG, SHOULD MAKE FULL CIRCLE CCW AROUND PART ORIGIN)
    N07G01Z.25F100.
    N09M02
    Feb 2010
    24
    Quote Originally Posted by beege View Post
    N03G00Z.25
    N04Z.1
    N05G01Z-.5F10.3
    N07G01Z.25F100.
    N09M02
    I will try here once will write back with results. My post was made with X3 Mastercam, I know the basics of the G03 with my 850 after reading about it but I have never done any arc's with it yet just drilled pattern holes and straight cuts.
    Thanks, Joe
    Feb 2010
    24
    That works, now to try something more, but I guess my post in x3 needs some help since it didn't work without editing.
  1. acramatic 850sx
    By KLH in forum Cincinnati CNC
    Last Post: 11-23-2022, 05:55 AM
  2. 850sx Controller
    By Hardywood in forum Commercial CNC Wood Routers
    Last Post: 08-18-2016, 11:39 PM
  3. 850SX problem
    By peterson76 in forum Controller & Computer Solutions
    Last Post: 01-27-2010, 02:31 PM
  4. 850SX problem
    By peterson76 in forum Cincinnati CNC
    Last Post: 01-25-2010, 07:35 AM
