586,096 active members*
3,635 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Possible to add thru-spindle coolant to 2000 Arrow 750?
    Apr 2004
    353
    I know this was an option, but ours doesn't have it. We have a 300 psi coolant pump, and would like to have it go through the spindle. Maybe on a valve so we can select? Anyone done this before?
    Aug 2008
    386
    The spindle required for TSC is different that non TSC spindles.
    You can get toolholders that add TSC. Probably a much cheaper option than changing out the spindle.
    You need more than 300 PSI for TSC though.
    Joe
    Nov 2006
    418
    If your machine is like my Arrow 1000, the drawbar is already hollow and threaded for the rotary union. I checked with MAG for the entire parts kit, and it will run about $5500 for all the pieces from them and about 8 weeks as I recall.
    I haven't gone that direction yet, still looking at some other alternative maybe....
  1. Cincinnati Arrow 1000 Coolant Question
    By zephyrmachine in forum Cincinnati CNC
    Last Post: 10-15-2009, 01:49 PM
  2. Arrow 500 spindle module
    By JWC in forum Cincinnati CNC
    Last Post: 09-16-2009, 04:21 PM
  3. Arrow 1000 spindle trouble
    By raygun in forum Cincinnati CNC
    Last Post: 03-03-2009, 04:32 AM
  4. Anyone ever change spindle motor in Arrow 750?
    By laka in forum Cincinnati CNC
    Last Post: 01-28-2009, 12:55 AM
  5. Anyone with a 2000 or newer Arrow 1250C?
    By absoluteron in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-17-2008, 04:34 PM
