586,067 active members*
4,872 visitors online*
Results 1 to 8 of 8
    Jul 2003
    212
    Haas Vf-2 Rebuild
    What would you all guess it would cost in parts to replace all 3 ball screws and all six linear ways on a VF-2?
    Jan 2004
    3154
    Parts like that on my 4020 Fadal (minus the linears anyway) would be about $7000 CDN using remanufactured parts. Haas should be similarly priced.
    www.integratedmechanical.ca
    Feb 2004
    7
    TOo.. Much -- guyzz--
    Buying a haas hurtz.. huh???
    Good luck DEAN
    www.datum1.com
    Datum 1 Engineering
    Ontario, CA
    909-923-8995
    Mar 2004
    69
    It's just like a Fadal, you never quite get it paid for, even when the notes end.
    TM
    Jan 2004
    539
    DEAN,
    Best way to find out is call Haas directly. I have never had to buy a part for mine, so I dont know if there is a better (cheaper/ discount) place to get them.
    "Buying a haas hurtz.. huh???"
    No.. not really
    Gary
    Sep 2005
    9
    When possible, I like to go with whoever made the part in the first place, it's mostly a LOT cheaper. A good bearing house should be able to price your ways and screws for ya.
    Ahead of the leading edge
    Sep 2005
    9
    When possible, I like to go with whoever made the part in the first place, it's mostly a LOT cheaper than buying it from Haas. A good bearing house should be able to price your ways and screws for ya. I've had my machines for eight years, and have spent about two grand in service and repair in that time. Best return on investment I have ever made.
    1880
    I forgot what the name said but the linear ways have the manufacturers name and I believe the serial number on them. take the cover loose on the Z axis and pull the shield out of the way and you can see it. (its a pain becuase those covers aren't fun to deal with.)
    You can probably order the guids directly but may be cheaper thru one of their primary distributers.
    thanks
    Michael T.
    "If you don't stand for something, chances are, you'll fall for anything!"
  1. Haas Lathe Reccomendations
    By imwllc in forum Haas Mills
    Last Post: 04-05-2012, 06:21 PM
  2. HAAS mini lathe
    By marto74 in forum Haas Lathes
    Last Post: 01-15-2004, 06:55 PM
  3. Searching Backwards
    By jonbanquer in forum Fadal
    Last Post: 07-29-2003, 12:53 AM
  4. HAAS Indexer Prodramming / Control
    By CAMmando in forum Haas Mills
    Last Post: 06-10-2003, 04:22 PM
