586,108 active members*
3,218 visitors online*
IndustryArena Forum > MetalWorking Machines > Sharp CNC > Sharp SV2412 Toolchanger Motor
    34
    Hi All,
    I'm trying to find out who the manufacturer is and what the exact part number is for the tool changer motor on my SV2412. The machine has the 16 tool option - and a previous owner removed the motor presumably to service another one of his machines. See attached pictures.
    Talking to Sharp hasn't been that helpful, as it appears that there are two options for the tool changer. The machine i have includes a gear reducer from LI-Ming machinery. It would really help me out if one of you can pull off the cover on your machine and send me a picture and the requested info (confirming that your machine uses the same gear reducer).
    This would be a huge help. Thanks again.
    Jun 2005
    232
    I have a sharp 2412 with a 10 tool carosel , Its scary sharp can't sell you a new motor whats there excuse? .Mine uses a small gear motor but its 3 phase 220 volt witch makes it hard to find and also has a brake on it, the motor on mine turns 56 rpm .Your gear box is made by a different company than mine .In my manual it lists a different motor number and mauufacturer thats not on my machine go figure. Notice on the second link you can configure a motor and gear box with the options you need..Hope this helps
    The motor number is 5ik60gn-smih the gear box is 5gn30k
    Here are links to the motor and gear box defennitions.
    http://twt.manufacturer.globalsource...ContactDetails
    http://akamai.globalsources.com.edge...1001624367.pdf
    Attached Thumbnails Attached Thumbnails SHARP MOTOR.JPG   SHARP MOTPR 2.JPG   DSC00451.JPG
    Tim
  1. SV2412 Fanuc Batteries
    By rbcmetalwork in forum Sharp CNC
    Last Post: 10-30-2009, 06:26 AM
  2. SHARP SV2412 TOOL CHANGE ISSUES
    By MXBONZ in forum Sharp CNC
    Last Post: 12-08-2008, 09:13 AM
  3. SV2412, Run Program off of card
    By H234 in forum Sharp CNC
    Last Post: 03-29-2008, 07:55 PM
  4. SV2412 Cutter Comp Question
    By javajesus in forum Sharp CNC
    Last Post: 02-26-2008, 03:03 AM
  5. diy toolchanger???
    By marcerasmus in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 10-08-2007, 05:24 AM
