Well,
I'm going to get going on my new thread to convert and modify my Quality Machine Tools PM-25-MV mill. For those that don't recognize it it's a variation on the BF-20 theme marketed by the QMT guys.
http://www.machinetoolonline.com/PM-MV-BenchMills.html
The 25 has about a 1HP motor per the spec but otherwise shares the same travels as the 20. I had some initial difficulty in getting it back together after dragging it to the basement. Got that sorted out and then the motor controller died on me. After some mail parts swapping they paid to ship the head back and repaired it there. It should be on its way back this week.
In the mean time I have put the X2 to work to make my first mod parts. I made some tram tunning blocks like machinechick showed off to allow me to fine tune the X tram using set screws instead of tapping with a hammer back and forth. If I need to tilt the head on an angle I can loosen one and swing it out of the way. Will need to drill and tap a 1/4"-20 hole in the carriage on both sides for them.
Second was a way to mount an X scale using the existing table stop nuts on the front of the table. I measured out the scale and I think the clamps will allow me to get the scale mounted with enough clearance to attach the readout to the saddle and still clear the gib lock handles. I wanted to have it tilted upwards on the mount but that doesn't appear to be possible really given the clearances. If these work then no modifications or holes will be needed to get the X scale mounted. Next will be the Z axis since I want to avoid using the quill for Z movement whenever possible. Last will be the Y but that may not really happen if I CNC first.
CNC conversion is now a priority. It appears I am developing carpal-tunnel from my day job and cranking on handles at night is not helping at all. I may be a one-armed man for a few months here in the future and so I am scrapping my plans of home-built circuitry and I'm going to look at getting some commercial drivers and so-forth. I'm going to see how well my existing 425oz/in Hobby-CNCs can move the tables around. I'm thinking something with more beef is going to be needed on the Z though.
Pictures attached:
First pic is the PM-25 in front of the X2 for a comparison.
Next shot is the X2 face-milling the material for the scale clamps with a Glacern FM-45 2.5" face mill.
Next shot is the two pieces ready to be drilled for the clamp screws.
Last shot is the X tram tuners on the left, one scale clamp on the top left, and the stock for another clamp and base on the right.
My tapping on the first part went poorly. Broke the 6-32 tap in the first hole. I've just got some ACE hardware Irwin taps on hand but I'm going to be going to HSS spiral taps in the future. instead of scrapping the toasted part I used it to make the top clamp by cutting off the section with the tap lodged in it. I've been using the spindle on the X2 to tap by putting it in nuetral and turning the tap using the spindle drawbar.
I'm waiting on a metric drill and endmill to drill the clearance hole and counter bore for the M6 socket cap that attaches the base to the front of the table. Using the existing hardware means metric sizes. The 11mm end mill will be used to cut a counter bore to allow the socket cap screw to fit flush under the scale.
Once all that is done I'll make the final cuts to the base to remove the corners outside the width of the top clamp. I imagine I will also need to fabricate some type of chip guard for the scale.
I'll try to keep this updated with successes and failures as I go.
