586,094 active members*
3,858 visitors online*
IndustryArena Forum > CAD Software > Autodesk > jpeg convert to dxf...can I do this?
Results 1 to 6 of 6
    Apr 2005
    47
    My CNC router is run with Kcam3 software. I use QuickCAD 8 to design with and save it as a dxf file. I'm wanting to do some inlay work and have some jpeg files that I want to incorporate in my CAD designs. Can I do this and how do I get it to convert to dxf so Kcam3 will run?
    Nov 2004
    65
    yes you can their are many jpeg , gif , tiff etc convertors available
    search with google for jpeg2dxf and you will find many ways
    anydwg.com springs to mind for one
    Dave
    If you're planning on doing inlays, I doubt you'll get useable results from a raster to vecotr conversion. Your best bet would be to import the .jpg into the CAD program, and trace it.
    Feb 2004
    44
    [B] I'm interested[/B]
    in learning more about your process of doing this. Sunday night I drew an Oak leaf in Autocad using splines and when I used sheetcam to process it I ended up with over 8000 lines of gcode. Not only that but my machine frozeup at line N160 when I tried to run it .
    Ger you copied a picture I put on CNCZone for a baluster and that worked great how did you do that?
    Jerry
    I think Eric did that, not me. Splines will always be broken up into lots of short, straight segments.
    Aug 2004
    3215
    Even Mach2-3 will do it, Import Image. then chose depth of black.
  1. G-Code to DXF
    By WayneHill in forum OpenSource Software
    Last Post: 05-19-2021, 11:26 PM
  2. DXF Catalog
    By CNCdude in forum News Announcements
    Last Post: 08-27-2004, 03:07 AM
  3. DXF or PLT files
    By signIT in forum DIY CNC Router Table Machines
    Last Post: 07-01-2004, 10:57 PM
  4. convert smartcam to dxf format?
    By imfool in forum Uncategorised CAM Discussion
    Last Post: 03-24-2004, 04:15 AM
