Hello all i need some help . I am working on a Leadwell ltc-15 lathe and the drive belt has sheared off all the teeth. The belt is original, is there an easy way to put on the new belt ? With out removing the bearing housing and lower drive shaft ?
This belt is about 5 cm width ( 720 8m )the lower belt not the one going up to the spindle shaft .
