586,655 active members*
3,137 visitors online*
    Apr 2010
    Step Syn Moter needed
    Hi. You have to excuse me as I am a printer by trade. I have a screen 3075 image setter. I the stepping motor is making a noise and not spinning the image drum as high speeds - at slow speed it is.
    The motor info is a
    STep syn
    103h8582-8042
    there is another no 6038448 and DC 1.5
    The motor is about 14 years old
    So please excuse my ignorance but do you know were I can obtain a new one.
    I'm based in the UK.
    I help would be great.
    Thanks Jake
    24223
    It could be a Slo-Syn product made by Superior Electric, if so it could give you a bit more to search on.
    Are you sure there is no extra loading or friction, as this could also be a cause.
    Al.
    Albert E.
    Apr 2010
    Thanks for the info. I will look them up.
    Regarding the load on the motor is low as it just spins a drum round. I will have look but i don't think there is a brake on the drum. I think the motor acts as a brake. Were the motor joins the drum there is a friction bracket. My brother gave it a name. We thought that it was slipping at the bracket.
    Silly question but when it works the motor is quiet. When it plays up it sounds like a drill.
    Thanks for your help.
    Cheers jake
    Apr 2011
    Quote Originally Posted by scrivs View Post
    The motor info is a
    STep syn
    103h8582-8042
    Thanks Jake
    I have one Step Syn 103H8582-8042 sanyo denki . my email address
    [email protected]
    Oct 2005
    2392
    As Al_the_man said it could be a fault other than the stepper motor.
    If there is too much load from friction from a failed bearing or some other drag the stepper will stall at high speeds. The stepper motor stall is what makes that high pitched "drill" sound.
    If the friction bracket is some type of vibration damper (common in office machines) and the rubber elements have perished or failed that might also cause the stepper motor to stall when it tries to go to high speed.
  1. Step by step Mastercam Art needed ?
    By Fonfon in forum Mastercam
    Last Post: 10-16-2009, 03:08 AM
  2. We need a Buesllato Optima Router Moter Rebuilt
    By Lorsherm in forum CNC Machining Centers
    Last Post: 09-10-2008, 04:12 AM
  3. step syn 4 wire hookup help needed.
    By nate in forum Xylotex
    Last Post: 03-08-2008, 06:58 PM
  4. sonceboz step motor info - needed
    By dan20041 in forum Stepper Motors / Drives
    Last Post: 03-28-2007, 02:33 AM
  5. hpgl and stepper moter control
    By Jan in forum Uncategorised CAM Discussion
    Last Post: 01-08-2004, 07:00 PM
