586,123 active members*
3,302 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > Reducing RF Interference
    Aug 2007
    215
    looking at the doc on the gecko site: quote: (Numbering is mine)
    Method One:
    1) Use a shielded 5-conductor cable for your motor to drive connection; 4 of the wires go to the motor leads
    2) while the 5th goes to the motor case. Return the motor case wire to the drive’s power supply ground connection.
    3) Ground the shield to your electronics control box at the control box end only, leaving it disconnected at the drive end.
    in my setup the PS ground is connected to the case, so isn't 1) and 2) effectively terminated at the same place and is this ok?
    24221
    This is where the reference to ground and common often get confusing.
    P.S. -ve or common terminal is often referred to as ground when it is not neccessarily at Earth ground potential.
    Generally the motor frame ground conductor is taken back to a central Earth ground point.
    As long as this applies, you should be OK.
    Al.
    Albert E.
    Aug 2007
    215
    Hi Al - thanks for your reply. Understood re: bad use of the G word, but in this case where it says ground I think it means ground. What I meant was, the doc seems to draw a distinction between the electronics control box and the drive’s power supply ground connection where certainly in my case, they're the same thing because I allways ground my chassis (and thought everyone else did too).
    Anyway - moving on to the next methods in the gecko doc (sorry if I'm being a bit thick here)
    Method Two:
    Install 20 to 50 uH chokes in series with each motor wire as close to the drive as is practical. The choke
    outputs go to the cable described above.
    Does that include choking the 5th wire or just the actual 4 "power" wires?
    Method Three:
    Install an L-C low pass filter (pi section) from your power supply to the drives. Make L 100uH; make C 1uF noninductive
    (multi layer ceramic capacitor). Use this in addition to both of the above.
    Do I use ONE of these filters BEFORE the fan out to my three drives OR do I use THREE of these filters AFTER the fan out?
    Ian
    24221
    No ground wire should have a choke in it.
    I cannot really speak to the L-C filters, but the traditional method has often been to use one filter before fan out, although three certainly would not hurt.
    You could always clarify it with Gecko themselves.
    Al.
    Albert E.
    Aug 2007
    215
    Thanks Al.
    Maybe Mariss will pop by - if not I'll run it by gecko's support. JFYI I'm working on a piece of home brew using a (10 bit 5V) ADC and when just reading a stationary potentiometer with the cnc control box off the reading deviates by maybe 10mV (1 or 2 points) at the most. Soon as I fire up the cnc controler the readings deviate by around 75mV (around 15 points).
    Ian
  1. Reducing Setup time
    By Ashish B in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-14-2009, 04:48 PM
  2. G73/83 Reducing peck
    By mattpatt in forum Fanuc
    Last Post: 03-24-2009, 01:03 PM
  3. New Application Note: Reducing RF Interference
    By CoAMarcus in forum Gecko Drives
    Last Post: 03-16-2009, 09:44 PM
  4. reducing output on psu.
    By thx1138 in forum CNC Machine Related Electronics
    Last Post: 09-17-2006, 09:47 PM
  5. Reducing amperage?
    By stdly in forum CNC Machine Related Electronics
    Last Post: 02-23-2006, 04:23 AM
