Flenser, what the heck is that funny looking stuff you're machining with the wavy lines in it? I think you called it "wood"????? Must be some newfangled "composite" material.
LOL!
Good job on applying the oil grooves. Peeps should bookmark that trick. It is so great to have a one shot oiler. I'm surprised at how fast I go through a gallon of way oil, though.
RE the ceramic inserts, you can definitely make your own toolholder out of mild steel just so long as you take lots of photos!
Are you sure the ballscrews require a ceramic insert though? Hoss would know, as he machines a bunch of them. I'd would've thunk regular carbide would work fine, but that it might shorten the insert's life. I guess I will find out pretty soon myself when I start up my lathe conversion again.
Cheers,
BW
Try G-Wizard Machinist's Calculator for free:
http://www.cnccookbook.com/CCGWizard.html
