586,121 active members*
2,985 visitors online*
IndustryArena Forum > CAD Software > Solidworks > Garbled Curves when saving SW2009 Drawings as DWG files
    Occasionally when saving a SW2009 drawing file as either a DWG or DXF (I've tried both ways) one or more curves in the drawing will end up as a series of tiny, self intersecting loops rather than a smooth curve as drawn in SW.
    I've tried opening the files in AutoCAD and Illustrator (and a few others) and DWG file is indeed NOT the same as the SW file.
    I can't find rhyme or reason to the problem: sometimes all is well, then the next very similar part when saved as a DWG will have a particular curve segment that when zoomed in on, will be self intersecting curves instead of one smooth curve.
    Any ideas what's going on?
    www.wilkins-knives.com
    Aug 2006
    259
    Could be a couple things.. What options do you have set for the splines? What version are you saving as? etc..
    Just when you thought you had it all figured out, all hell breaks loose..
    Version is R2000-2002 and splines are set to export splines as splines...
  1. Graphics Card ? : Quadro FX3000 SW2009
    By KevinWilkins in forum Solidworks
    Last Post: 04-30-2009, 07:21 AM
  2. Stl files will not create curves..
    By jaru-eri in forum Digitizing and Laser Digitizing
    Last Post: 01-27-2009, 09:51 PM
  3. Saving program files
    By Troy Kingan in forum Hardinge Lathes
    Last Post: 10-22-2008, 04:35 PM
  4. saving files with a DWG or DXF
    By casta-baga in forum Mastercam
    Last Post: 08-07-2008, 04:02 AM
  5. Replies: 2
    Last Post: 03-09-2007, 08:47 PM
