Hello guys!
I´ve made a routing machine wich get a PMDX-125 breakout board with 3 CNC AC Servo Drive ASDA-B on it and I´m using the Mach3 software.
Well, everything is working fine, but when I´m doing some work with the machine, I get some mistakes on measures.
For exemple, I do a mirrored part on the same drawing and the final product gets almost 1mm of differecence. I can see on the CNC code that is everything ok, but on the machined part I get this difference.
What can be the problem? I guess that my xml for Mach3 is ok, but I think that I got some noise for the board and drives and I don´t know how to eliminate that problem.
I hope you guys help me!
