586,060 active members*
4,391 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > M151 Holding piece in both chucks and lathe from Second chuck. HOW?
Results 1 to 13 of 13
    Sep 2009
    16
    Unhappy M151 Holding piece in both chucks and lathe from Second chuck. HOW?
    We Have this option on our Multus B400W
    G140 L spindle mode selection
    M110 L spindle C axis mode ON
    G00 C30 C axis positioning
    VCPHH=90 Specify phase diff L-R spindle 90 degrees
    M892 C axis mode ON for opposite spindle
    M248 Chuck clamp on Right spindle
    M889 C axis synchronization ON
    G00 C100 C axis movement with synchronization
    M13 SB=100
    G01 C200 F1000 G94 C axis movement with synchronization
    G00 C0
    M888 C axis synchronization OFF
    M12
    M249 Chuck unclamp on right spindle
    M891 C axis mode OFF for opposite spindle
    M109 L spindle C axis mode OFF
    This is the model above our agent sold to my boss...
    this is the model i need to convert so that i can ...
    Take a piece from main spindle,(left)
    Pass it over to the Sub spindle,(right)
    Hold it with both spindles,
    Then lathe a thread along the work piece (now sitting between both spindles).
    Cut it FREE from Main spindle,
    Sub spindle with work piece (W) now moves home and away,
    leaving the Robot to go into the machine to retrieve the finished piece from the Sub spindle, (yes there will be a small piece left in the main spindle, this i can remove with the robot or machine)
    How Do i convert this model to do what i want?
    i cant see how i would fit G141 into this as i want to use the Sub spindle when i create the thread.
    Please help out a newbie with no help.
    piece needs to be done and our agent is not replying to me.
    i have to say he is a good guy and helpful but he just aint there for me as much as i would like.
    Mar 2009
    1982
    what option do You have?
    why You need C axis?
    are You sure, that M889 and M888 are usable here? I'm asking, because I don't know. I imagine this operation quite different way.
    You need to have possibility to synchronize both already synchronized to each other spindles to Z feed to cut thread that way. Are You sure, that You have that option on Your machine?
    Sep 2009
    16
    Well we dont need C really but we could certainly use
    VCPHH=90 Specify phase diff L-R spindle 90 degrees.
    this model i have originaly written in my first thread question simply is the model purchased for the machine.
    every code you see here SHOULD be fully functional.
    all we need to do i guess is hold with both spindles and then set them in rotation synchronised.
    Sep 2009
    16
    THESE ARE OUR 2 PURCHASED MODEL OPTIONS FOR OUR MACHINE.
    OPTION NR 1 PURCHASED FROM AGENT.
    (--------- M151 Syncronised C axels, Both engaged with power.-----------)
    (--------------------- Spindle acting as DUBB -------------------------)
    G140
    G50 S2800
    M83 M248
    M151 M883 M210
    (MOVE W)
    G97 S1000 M42 M3
    (BEARBETNING)
    M5
    M2
    OPTION NR 2 PURCHASED FROM AGENT.
    (--------------- M110 Syncronised C axels, Both engaged.---------------)
    G140
    M110 (L Spindle C-axis mode ON)
    G0 C30 (C-axis positioning)
    VCPPH=90 (Specify phase diff L-R Spindle 90 degree
    M892 (C-axis mode ON for opposite spindle)
    M248 (Chuck clamp on R-spindle
    M889 (C-axis syncronization ON)
    G0 C100 (C-axis movement with syncronization)
    M13 SB=100
    G91 X-.1 (Incremental)
    G90 G1 Z200 F1000 G94
    G0 X=VPVLX C0
    M888 (C-axis syncronization OFF)
    M12
    M249
    M891
    M109
    M2
    Sep 2009
    16
    Okay my Agent Contact has called me, i knew he would.
    it appears this is the model we should be using to lath a thread between the 2 spindles.
    G140
    G50 S2800
    M83 M248
    M151 M883 M210
    (MOVE W docking gripping passing over etc)
    G97 S1000 M42 M3
    (BEARBETNING)
    M5
    M2
    Feb 2009
    202
    Multus will ALWAYS have C axis. C axis Sync is an option. I have turned a center in the sub spindle and used torque skip to seat the center and driven the part with the main. You might be able to do the same, not with a center but clamped with the sub. Beware this will be hard on the main spindle.
    Jun 2008
    372
    "Beware this will be hard on the main spindle. "
    And the sub spindle as you are essentally taking the preload of the subspindle bearings by using ut as a Centre
    Feb 2009
    202
    Correct. After all it is a Multus.
    Sep 2009
    16
    Great to see you guys talking over my problem.
    Well i am back after a failed attempt to reach Mexico.
    Got stuck in England which was pretty good fun in the end.
    Now i return to see our multus with no M spindle in it???
    seems the coolant was not good and fried the bearings, 4 weeks out of action.
    this delays my trials even further but lets see this as positive as i should be fully armed with you information for test day.
    You talk about stressing the sub spindle but as i will be working the peice from main spindle and then passing it over to the sub spindle i have no choice do i?
    after all i need to hold the peice in the sub spindle ready for the robot to take it out, after placing a new peice in the main spindle.
    Very curiouse to see how your program would look to do this
    both using the sub as a dub (dub in sub)
    also as a gripping sub which is what i need.
    thanks for your interest in this post.
    Sep 2009
    16
    you say
    this is what we need, surely the machine should cope with this.
    are they driving together or is one just free running, being turned by the opposite spindle.
    i thought they were both driving at the same time but synchronised?
    Jun 2005
    142
    Turning between synchronized spindles is fine.
    Synchronized Milling between spindles is an option that we don't have, but using the sub as slave has worked fine so far.
    We have been told by Okuma to use 30% load on W axis (sub), when setting the transfer position. That seemed a lot to me, especially if we start doing lots of billeted or cast work.
    You can see milling between spindles here, [nomedia="http://www.youtube.com/watch?v=asG5DL0y1AE"]YouTube- Okuma Multus B300 Screw Milling[/nomedia] (master/slave), but not the synchronized turning (too boring!).
    Re: M151 Holding piece in both chucks and lathe from Second chuck. HOW?
    hi, i am newbie of the multus. the shop i am working at now just bought a multus B250ii, they want me to turn and milling a part between both spindle. i would like to know more about how and what Gcode need to be in the program for mmilling between sync spindle.
    Jun 2015
    4154
    hy manhtranc
    they want me to turn .... a part between both spindle
    both spindles must have found their S origin, so jog each spindle ( or turn each one by hand ), just a couple of revolutions, like 2-3 max spins, so to get rid of CD****
    manual mode, clamp your part with both chuck
    G140
    G50 S2000
    M151 M210 M883
    G97 S250 M03
    if it works, then continue with normal turning codes
    manual mode, clamp each chuck with individual parts, thus don't use long part yet
    G140
    M110
    M892
    if it works, then more codes and parameter related to C origins, are needed before using normal milling codes ( i will try to help you with them ); if it does not work, pls share error and image with setup ( will try an alternative method ) / kindly
  1. Replies: 8
    Last Post: 04-18-2014, 02:03 PM
  2. Boring soft chuck jaws for ID holding?
    By SRT Mike in forum MetalWork Discussion
    Last Post: 03-15-2013, 07:19 PM
  3. Which chuck for holding drill bit?
    By clanbuster in forum Vertical Mill, Lathe Project Log
    Last Post: 08-27-2011, 08:30 PM
  4. collet chucks - lathe
    By ace of spades in forum Want To Buy...Need help!
    Last Post: 11-10-2010, 01:45 PM
  5. holding a large piece
    By fatboy55 in forum Charter Oak Automation Support Forum
    Last Post: 11-10-2009, 10:12 PM
