586,047 active members*
3,827 visitors online*
Results 1 to 6 of 6
    Apr 2010
    Milling PCBs - Gerber to G-code?
    Hi - we have a fairly nice 3 axis Fadal milling center with a tool changer. We use MasterCAM with Solidworks to mill parts. I use Altium Designer to design PCBs. I would like to use the milling center to mill out PCBs.
    I've tried exporting DWGs from Altium Designer and importing them into Solidworks - but the traces always import with zero width.
    I'm wondering if I'm going at this from the wrong angle - what about going from Gerber code, output from Altium Designer, and running some sort of Gerber to g-code converter on it?
    Or any other ideas? Thanks!
    Aug 2008
    247
    PCB to G-Code
    SourceForge PCB to GCode Project:
    RepRap discussion from 2009
    One more.
    Hope this helps -- or at least points you in a productive direction.
    ~John
    Apr 2010
    Quote Originally Posted by johnohara View Post
    One more.
    ~John
    Hi - The pcb2gcode project looks interesting, but it seems to be pretty incomplete and not very popular. Scares me. I'll still see if I can get it to compile though. It scares me when a project doesn't even include binaries...
    Aug 2008
    247
    Seems as though there was a lot of activity in late 2008 - early 2009 and then it lost momentum.
    Hmm. Too difficult or a different solution?
    Apr 2010
    Not sure. I also ran across this project: http://gcam.js.cx/index.php/Main_Page but from discussions in their forums it sounds like the Gerber support isn't all the way there just yet.
    Aug 2008
    247
    A Different Spin
    I tried the Thomas Gootee method a couple of years ago and it works. The traces are very precise.
    Perhaps you can use his method to create the board then use the mill to accurately drill the holes.
    A thought.
    ~John
  1. G & M Code on a Gerber Dimension 200
    By quaturbo in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-16-2012, 01:15 AM
  2. Accuracy of milling PCBs for surface mount?
    By logik in forum DIY CNC Router Table Machines
    Last Post: 09-26-2010, 05:34 PM
  3. Underlay/Backing Material for milling PCBs
    By gtrdude in forum Material Machining Solutions
    Last Post: 02-27-2008, 07:00 PM
  4. gerber milling
    By smarbaga in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-16-2005, 02:51 AM
  5. Gerber 2 G-code
    By ACME in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-09-2005, 02:16 AM
