I surely hope someone can shed a little light on my situation I have an SX3
and am having the crappy common Z axis issues
after removing the gib it did not look in too bad of shape, smooth on one side at least' and straight
I guess i should start with this the machine was purchased from grizzly but was in an open crate, but it appears that my z gib wont adjust right, if I crank it in balancing turning both the screws together it moves in great but the lower screw rides off the side of the bottom of the gib and the head starts to hesitate when changing direction as well as the gib adjusting screw on the top rocks back and for significantly during direction changes
I know i know same ol' woes as heard before from many others
so rather than trying to use shims to fix the problem i decided to mill one from oilite as i already have the stock
what is the proper angle for the gib i understand that there will be some fitting involved but from searching i find that the long taper is .5 deg and the side tapers are 60 deg but lined up with my 6o deg bevel cutter the angle is just a little off
