586,115 active members*
3,404 visitors online*
    Nov 2008
    21
    Bridgeport Torq Cut 30
    drives will not start up.getting no errors but on the maintenance page it says "drive command failed at bmdc".After several attempts you can get the drives to start up.We can run some parts for a hour or so and then get a BMDC COMMUNICATION ERROR.
    Nov 2008
    21
    now after powering down it goes to the machine check blue screen and goes no further.done BMDC (B3T.EXE) board check it says BMDC NOT RUNNING....LOADING BMDC.....WAITING FOR BMDC...BMDC3 TIMEOUT
    Nov 2004
    3028
    Either software is corrupted (or CMOS not set correctly) or BMDC is not communicating.
    Remove BMDC carefully and clean edge connector with a soft eraser and reinsert.
    If still not working try looking for B3T.EXE in DOS on your mass storage device. Run that and see what it tells you.
    George
    Nov 2008
    21
    Ok....got it going and it ran for a whole week and got the BMDC communication error again while it was sitting idle whem operator was on break.Pulled BMDC board and reseated and its running again.All board contacts have been cleaned prior to this.Any ideas?....HELP!!!!!!!!!
    Charlie
  1. Bridgeport Torq-Cut TC 3G??
    By Kristjan in forum Bridgeport / Hardinge Mills
    Last Post: 11-02-2017, 11:47 AM
  2. Bridgeport torq cut-22 problems!!
    By baystard in forum Bridgeport / Hardinge Mills
    Last Post: 01-17-2008, 08:22 PM
  3. bridgeport torq cut 30 shot pin
    By porkchop21 in forum Bridgeport / Hardinge Mills
    Last Post: 08-08-2007, 05:21 PM
  4. Bridgeport Torq-Cut 2G-?????
    By bherr in forum Bridgeport / Hardinge Mills
    Last Post: 10-21-2006, 06:56 AM
  5. Bridgeport Torq Cut 22: What lubricants? Where? How?
    By vettespeed in forum Bridgeport / Hardinge Mills
    Last Post: 06-24-2006, 07:38 PM
