586,446 active members*
3,746 visitors online*
    Apr 2010
    Exclamation Fanuc 21i Lynx Error
    Hi.
    We currently have a problem whit our Fanuc 21i Lynx.
    The error number is : 2050
    LUB PRESSURE IS DOWN OR LUBRIFICATION OIL LEVEL IS LOW. CHECK LUB UNIT AND REPLENISH THE OIL
    We checked every oil tanks and they were all okay. Any idea what it could be?
    Oct 2005
    332
    Normally sensors do not like oil or lubrification. Can be the sensor damaged.
    Try manually to switch them and/or see any electrial changes.
    If no change -> sensor is damage.
    Apr 2010
    We found out it was related to breakers. It's seems the pump only spindle but it doesn't suck up the oil.
    Apr 2010
    You can close this. We called a engineer to fix this.
  1. Replies: 15
    Last Post: 07-09-2020, 09:08 PM
  2. Fanuc 0T error 310,320 and 520
    By kfmc in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-01-2008, 09:49 AM
  3. Fanuc OT Error 410
    By jgj in forum Fanuc
    Last Post: 07-07-2008, 06:08 AM
  4. FANUC OMB Error
    By malasjo in forum Fanuc
    Last Post: 12-31-2007, 12:23 PM
  5. Fanuc 6MB Error LED
    By tsalpha in forum Fanuc
    Last Post: 01-05-2007, 03:51 PM
