586,036 active members*
3,823 visitors online*
Results 1 to 8 of 8
    Apr 2010
    G65... unknown G code?
    Hi all, I'm new to the zone. I have a problem with a Niigata HN63C with a Fanuc 15-M control, it wont accept a G65, or any variable programming. Does anyone know what parameter it might be to enable macro programming? Thanks!
    Feb 2006
    992
    "unknown G-code" alarm? if that's the case, you out of luck even turn parameter on 'cause u dont have macro option.
    The best way to learn is trial error.
    Apr 2010
    Thanks. Cheers!
    Jun 2008
    1511
    You more then likely don't have macroB on your control but as a test program #1=5 in MDI mode. If you get an alarm then you don't have macroB. Let me know.
    Stevo
    Apr 2010
    Hey thanks, no it doesnt work, it says invalid break point of words. when ever i try to use any "IF" or "GOTO" words, it seperatets them into single letters. It's messed up, I have never ran a mill that didnt work with G65.
    Jun 2008
    1511
    PM me your 9100 parameters and I will take a look at them. They should go from 9100 to about 9160 or so.
    Stevo
    24221
    Do you have a print out or hard copy of your 9000 parameters you can email?
    Al.
    Albert E.
    Apr 2010
    Yes I have a copy of the machine parameters, and can email as well.
  1. UNKNOWN FAULT CODE
    By CNC_BOB in forum OKK
    Last Post: 11-18-2022, 07:57 PM
  2. Unknown controller
    By bjtoo in forum PIC Programing / Design
    Last Post: 03-23-2010, 06:42 AM
  3. Unknown g code G23 error?
    By keaton64 in forum Mach Plasma / Laser
    Last Post: 09-22-2009, 03:33 AM
  4. Unknown steppers
    By wolfdagon in forum Stepper Motors / Drives
    Last Post: 03-12-2007, 01:52 AM
  5. Unknown Fanuc PSM
    By ulihuber in forum Fanuc
    Last Post: 08-11-2006, 01:13 AM
