586,648 active members*
2,836 visitors online*
Thread: arcs
Results 1 to 6 of 6
    Mar 2009
    291
    arcs
    How do i snap a arc between two circles?Its a .18 r and the blue print does not give a center point for this.
    Attached Thumbnails Attached Thumbnails 2.jpg   5101171-2010-04-20-15-23-27.jpg
    Attached Files Attached Files
    Jun 2008
    1838
    This any help ??
    Regards
    Rob
    :rainfro::rainfro:
    Mar 2009
    291
    arcs
    Looks great!Can you tell me how you did this?
    Thanks Dave.
    Jun 2008
    1838
    Hi Dave
    Not sure if I did it the correct way but it seemed to work OK, you would be the best judge of whether the geometry is now what you wanted !!
    Anyway, here is what I did :-
    1) Went to "Utilities" then to "Break" then to "Divide" and broke each of the circles that had the be "joined" by the 0.18 rad into 4 (Quadrants).
    2) Next I went to "Arcs" then to "Fillet" and set it to the 0.18 rad required
    3) Then did a normal fillet operation from one quadrant to the one on the other circle and the result is what I posted.
    Worked out pretty easy really
    Have a go yourself and see if it works for you, FYI I am on Build 1493
    Regards
    Rob
    :rainfro::rainfro:
    Mar 2009
    291
    arcs
    i'll give it a try.I'm also on 1493 and not to sure on the next bulid.so i will stay with 1493.Thanks again for the help.
    Jun 2008
    1838
    Quote Originally Posted by 1234567 View Post
    To be honest unless you need the better Lathe updates in 1595 and you are mostly doing mill work then you would be better sticking with 1493 for now, it seems to be the more stable of the 2 !!!
    Regards
    Rob
    :rainfro::rainfro:
  1. arcs using I and J
    By MadPickinSkills in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-08-2009, 08:54 PM
  2. Arcs
    By Anxious in forum Post Processors
    Last Post: 09-18-2008, 04:41 AM
  3. I and J 3D arcs
    By mmachining in forum BobCad-Cam
    Last Post: 02-14-2008, 08:01 PM
  4. 3d arcs?
    By stevespo in forum BobCad-Cam
    Last Post: 09-01-2007, 02:02 AM
  5. Huge Arcs HELP ?????
    By Biggermens in forum Mach Software (ArtSoft software)
    Last Post: 04-26-2007, 02:50 PM
