586,361 active members*
3,457 visitors online*
IndustryArena Forum > CAD Software > Solidworks > creating aircraft fuselage
Page 1 of 2 12
Results 1 to 20 of 23
    May 2005
    I've been trying to create an a320 fuselage, but can't seem to get it right.
    I've sketched a side view of the fuselage, and a front view of th section (a circle). Now I'd like to kind of extrude or loft the circle "inside" the side view sketch, so it becomes a solid fuselage. But I'm really bad at it, and have no idea of how to do it. Can anyone help me out on this one?
    Jan 2004
    3154
    This would take awhile to explain, but you aren't very close to getting this to work.
    I suggest you go and do the tutorial provided with SW on lofts and then post any new questions you may have.
    www.integratedmechanical.ca
    Mar 2004
    500
    Try extruding the two side views then intersect them where they line up in 3d space. Not sure if this works in Solidworks done it in others. Just an idea, not sure if it would work.
    Jul 2003
    148
    File
    What version of SolidWorks? I have 2003-2004. So if your working in those versions you can post the file and I'll take a look.
    Aug 2003
    812
    Darbee, on the money. You will have to sketch the profile of the body all along it's length, then loft through all of the profiles.
    Think of it like building one of those old balsa RC planes, with the ribs of the fuselage, then you skin it with the loft. You can add control curves if you need to as well.
    The software has a tutorial with it in the help files on lofting.
    May 2005
    Hello!
    Thanks for the replies and suggestions.
    I have done the tutorial of course and did some reading in the documentation, but i'm still having problems getting the guide curves right.
    The "ribs in balsa plae" approach is a good one, but that means a lot of ribs (a lot of planes!), when i actually only need one shape. I'll keep trying...
    Aug 2003
    812
    You only need one profile but in 3d the fuselage shape is almost constantly changing as you move front to back. You will need that info in your model if you want to do it right.
    If all you need is a rough estimation of an aircraft body then just draw the profile, extrude it and put big fillets on all the edges to round it all out.
    Did you do the online tutorial on lofts? Thats pretty much all you need to know.
    It will take a long time, what you are trying to do...well guys at Lockeed and boeing get paid big bucks to do it.
    Sep 2005
    1660
    Making a Fuse in SolidWorks isn't to hard, it just takes dedication to doing it correctly. The best way I've found to do it is in conjuction with a form of mechanical [ the same way it was done when hand drawn] conic's. It's nearly impossible to describe via a forum board. An A320 fuselage should be pretty easy to do, I wouldn't use the top/side views for anything but refrence. Primarily most of my modeling of this type is done via stations down the length of the fuse. I constrain the station profiles to the top/side profiles via contruction lines [ make sure you side/top profiles are fully constrained]
    The basic's for making the 320 fuse would be as follows [ at least how I'd do it] Get your constrained top/side profiles, start w/ a station at the location where the fuse becomes constant in shape [maybe 15% back from nose], extrude that shape back to the point where the fuse starts to taper in again [ disregard the wing fillet location and shape for now]. Creat maybe two stations for the nose section [ you may need more to get the front windows to look correct.. I'm trying to remember what they look like..] Do a loft from about 3% back to the extruded section with a "normal to" end condition. Do the same at the tail and then finish the nose off w/ a "dome" function. This should get you pretty close to what you want, you then put in the airfoil station where the fillet ends and is blended into the wing, you put a 3d sketch onto the side of the fuse, or just use a projected split line to split the skin of the fuse in a shape that matches the fillet profile on the side of the fuse. Convert that split line into a 3d sketch and loft that into the previously created airfoil shape. You may need to add guide curves to get the proper shape. This may also require some clean up "fillets" to get blended lines. I find that at this point, instead of doing the same on the other side I like to do an extruded cut and litterally cut the fuse in half [ remove 1 complete half] then do a body mirror with merge and you'll have a perfectly sym model.
    thats a short version of how to do it, Attached is a model I did on my own design for an airplane.. it took some time and I used the conic's style driven model I wrote about above, its an alot more complex way of doing things but I like the results. PLUS... the major advantage is that I have a non constrained spline control line, which by simply opening that sketch and draging the spline, I can change the curvature of the fuse stations from a very square look [ looking from the nose aft] to a perfectly circular or even hyperbolic [ or is that parabolic] profile. All by dragging 1 spline. This spline drives several [ over 80.. I checked] formula's and smooths things out b-e-a-u-t-i-f-u-l-l-y.. Like I said.. it took a while to set up but it was well worth the time.. Here's a sample of what it will produce...
    JerryFlyGuy
    Attached Thumbnails Attached Thumbnails RENDER11-resized.jpg   Conics R1-3.12.JPG
    Nov 2004
    30
    Hey JerryFlyGuy, are you thinking about building the canard aiplane?
    Could you post the SW file?
    May 2005
    Very good reply, thank you!
    Sep 2005
    1660
    Quote Originally Posted by Inventthis
    Inventthis, Well I actually do plan to build it, I was at the point of ordering all the laser cut parts to build buck's for it and then got the CNC bug again. I started doing some looking around the web, came across this site and realised that hobby level cnc has come a long way since my last look. I'm currently building a 20 x 10 x5 router for cutting the buck's and molds for this a/c. I plan to start w/ a 1/4 scale R/c model and get the aerodynamic's down and then build the full size a/c. As far as posting the file, well.. since I spent as much time as I did getting things where they are.. and my financial future may be based on this design.. it might be best for me to hang onto this for now.. thanks for the request though..
    JerryFlyGuy
    Apr 2005
    5
    Jerry Fly Guy
    Very nice looking airplane. I have come very far learning SW and have created some very basic airplanes, fuselage, tailplanes and all the rest. Like Inventhis I would really enjoy looking at the SW file just to see what is takes to make a nice smooth fuselage. I was able to follow your instructions here but I am more of a hands on guy, where I like to take things apart to see how it all works.
    Thanks alot,
    Chris
    Sep 2005
    1660
    Quote Originally Posted by Scoobyvroom
    Jerry Fly Guy
    Chris I appreciate the interest! I've been looking for a website that better decribes the process of mechanical conic's. However, as of yet, I've not found anything on the web that would properly explain it. The best option I know of to learn it is to go HERE and purchase Mr Raymer's book, 'Aircraft Design the conceptual Approach' You can also find copies of it on Ebay. In it, is the best explination of the step by step process for hand drawn conic's that I've come across. All you need to do is apply this to individual sketch's at your stations along your fuse and voila! I'd love to see some pic's of some of your work! It's great to view other's idea's and get new perspective's of our wonderful world of invention! When it comes to organic design in solidworks the old saying of ' if at first you don't succeed...' is VERY true. It took me several years to learn what I know.. and I don't know that much
    Jerry
    1880
    how about giving a quickly done sample of what you just described. Not the model that you posted but something quick and dirty?
    thanks
    Michael T.
    "If you don't stand for something, chances are, you'll fall for anything!"
    Sep 2005
    1660
    Miljnor, there is no quick nor dirty on this. We're talking a sketch w/ 50-60 lines on it and a formula for each line. Trust me.. spend the $10 for the book.. it will be money well spent. Once you see what I'm talking about you'll better understand.
    Jerry
    JerryFlyGuy
    The more I know... the more I realize I don't
    1880
    i would but the $10. dollars is more like $90! Unless you have a better source for it.
    thanks
    Michael T.
    Sep 2005
    1660
    Quote Originally Posted by miljnor
    Miljnor they come up fairly regularly on Ebay
    Here's one right now.... $25
    Here's another book by the same author-However it may-or maynot have this conic's details in it. I don't know
    Set up a daily search on ebay under books for 'Aircraft Design Raymer' and you'll get the notices when they come up.
    Jerry
    JerryFlyGuy
    Nov 2004
    30
    JerryFlyGuy,
    I will really encourage you to move ahead with your airplane design. Actually I was going the same route designing my own airplane and fly it. I built a CNC plasma table for that purpose (I finished it 3 months ago- see pics) and I put my aircraft project in stand by for a while. I would like to make more money first, starting a business that will not require too much money. I took some aircraft design classes when I was in grad school and my dream I've been to build my own aircraft. The Raymer book is very good , I have it as well . RDS-student should be helpful as well.
    Sep 2005
    1660
    JerryFlyGuy,
    Thanks Inventthis, I do plan on doing the aircraft. What got me started on the whole cnc thing was [ maybe I've posted this before] building the buck for the molds on a 1/4 scale model. I had the laser cutting all designed and was just about to order it, when I got back to thinking about doing it via CNC and went back online.. found this site and realised that the hobby level of cnc had drasticly changed from when I'd last looked at it.. the rest as they say was history. Now I just need to get this stinkin milling/router table done and I'll be away
    I must say I really like your table! It's refreshing to see a table that is all finished out to the last detail, painted and then re-assembled. Makes a world of difference in the first impression. Have you found much movement in your y axis [ is there a second rail on the opposite side of the gantry?] are you using it as a router also? If so, how are you holding your parts down to the louvered cutting table?
    Jerry
    JerryFlyGuy
    Apr 2005
    29
    What sort of plane are you looking for or looking to create?
    I can get you about anything that i convert from a .3ds file to a step and then I will try and get that small enough to send you.
    A747, P51 Mustang, C5, F15, F16, a Blimp, or a MIG that is attached.
Page 1 of 2 12
  1. Creating a PCB?
    By GunnySnow in forum CNC Machine Related Electronics
    Last Post: 06-15-2004, 04:11 AM
  2. Creating a chopper drive with discrete components using the L297
    By tpworks in forum CNC Machine Related Electronics
    Last Post: 05-31-2004, 06:04 PM
  3. Creating a Dos Environment Via Partition Magic?
    By paulried in forum Computers / Desktops / Networking
    Last Post: 05-11-2004, 03:20 AM
  4. Can someone help me creating this "part"?
    By scopEDog in forum Employment Opportunity
    Last Post: 05-07-2004, 04:19 AM
  5. creating surface
    By Mortek in forum OneCNC
    Last Post: 05-20-2003, 04:11 PM
