586,105 active members*
3,360 visitors online*
    Apr 2010
    need a vendor/fabricator in the NY area.
    Hello,
    I am working with 1" thick, 1/2" thick and 1/4" thick acrylic sheet that I need to have cut with a proper CNC machiene. The project will be made up of rectilinear pieces and components that must fit together acuratly. I have drawn it on AotoCad as well so its all layed out and can provide whatever drawing a machenist needs to plug into thier CNC computer. I would also like to purchase the acrylic from the same place as well. looking for Polycast cast acrylic sheet for the 1" and 1/2", the 1/4" can be less expensive grade. 1" will be clear, 1/2" will be black and 1/4" will be a combo of red and clear.
    can you help me find a good CNC machienist in the NY area approx 1/2 hour north from NYC. I will also travel upto 1 hour from my westchester home. thanks so much for your help. also I will need about 50 or so pieces cut can you give me an idea how much I should be looking at for this type of project?
    Sep 2009
    313
    A HUNDRED BILLION DOLLARS!!
    Apr 2010
    no one???
    Apr 2005
    345
    I am in Binghamton, which may be farther than you want to travel. But if you end up with nobody close feel free to contact me.
    Scott
    [email protected]
    http://www.scpconcepts.com
  1. A Really Exceptional Vendor....
    By SCzEngrgGroup in forum Benchtop Machines
    Last Post: 01-28-2010, 04:18 PM
  2. looking for vendor
    By atoroguy in forum Linear and Rotary Motion
    Last Post: 10-09-2009, 03:47 PM
  3. Vendor Rating
    By pete00 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-30-2009, 12:17 PM
  4. Looking for a low volume CNC vendor
    By sn96 in forum MetalWork Discussion
    Last Post: 01-21-2009, 10:06 PM
  5. Vendor Needed!
    By royculvert in forum Uncategorised MetalWorking Machines
    Last Post: 05-28-2008, 11:11 PM
