Power Supply Recomendations
Hello from B.C,
I am using three of these stepper motors on my benchtop cnc plasma cutter:
Frame Size: NEMA23
Step Angle: 1.8 degree
Voltage: 3.6V
Current: 2.0A/phase
Resistance: 1.8Ohm/phase
Inductance: 2.5mH/phase
Holding torque: 9.0Kg-cm 125 oz-in
Rotor inertia: 300g-cm2
Detent torque: 0.4kg-cm
Number of wire
leads: 6 (See color code diagram)
Weight: 1.54lb (0.7kg)
Length: 2.21” (56mm)
I am now in the works on getting a power supply, but i am not to sure on what size I should get. I have either been looking at a 24v 14 amp power supply or a 36v 10amp power supply.
I am leaning toward the high volt low amp power supply do to that this is a plasma cutter since I want high speed and there is low torque on the machine.
any suggestions would be appreciated.
Rob C
Mechanical Designer/ Welder Fabricator.
