586,111 active members*
3,097 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Vertical Mill, Lathe Project Log > 2nd Build - Steel Tube, Moving Gantry Style, Mill / Router
Results 1 to 20 of 74
Threaded View
    Nov 2003
    299
    Several years ago I built my first cnc router. It started as a plasma machine and evolved into a plasma/router/light duty mill. It never really was built to mill metals but, milling metals is mostly what I need it to do.
    So, I decided it was time to build a new machine. This one will be much heavier then the first one. Hopefully it will mill aluminum and steel without too many problems.
    The drive system will be AC servos run through a 1856 Galil card and Mach3. As far as speed goes, the goal is 600+ IPM on rapids.
    Pictured is the raw materials for the build. 6x8 tube, 1018cr steel for mounting the linear rails. Also pictured is the gantry partially welded. 6x8" steel tubing, 1/2" thick wall, 70" long. Weighs about 300# with the flat bars welded on. Add the z axis and a spindle and the "mass in motion" will be over 500#!!
    Some more specs:
    travels: x 59", y 33", z about 15"
    3/4" precision acme screw 2 turns per inch direct driven 1:1 by 1100w ac servos
    Full flood coolant system
    BT30 spindle rated 15000rpm (I know it will be grossly underpowered, but I want to try driving the spindle with a 1kw Automation direct servo through Machs spindle control)
    Attached Thumbnails Attached Thumbnails DSC_3809.jpg   gantry2.jpg   gantry144534.jpg
  1. Will Build a Moving Gantry ROUTER-comments appreciated.
    By CNCfun&games in forum CNC Wood Router Project Log
    Last Post: 12-25-2016, 01:06 AM
  2. Moving Table, or Moving Gantry? (For Router)
    By Cryptonic26 in forum DIY CNC Router Table Machines
    Last Post: 04-20-2011, 08:38 AM
  3. First build! 3-Axis Gantry-style CNC
    By TheBakachan in forum DIY CNC Router Table Machines
    Last Post: 04-18-2009, 02:10 AM
  4. New build! Gantry style based on Ahren's parts and 80/20 extrusion
    By groomden in forum DIY CNC Router Table Machines
    Last Post: 04-03-2009, 04:40 AM
  5. Moving Table vs Moving Gantry; Dremel vs Router
    By chuckknigh in forum DIY CNC Router Table Machines
    Last Post: 03-28-2007, 02:48 AM
