586,052 active members*
4,425 visitors online*
    Nov 2009
    59
    Machined size is double
    Just finished my second milling machine project and am experiencing a weird issue. When I machine something using one of the canned cycles (wizards) in Mach 3 the machine cuts the exact size I program. When I machine something programmed in Surfcam, the machine cuts the part (circular pocket) twice as big. The code program indicates the correct dimension but the machine cuts it double.
    Perplexed in SLC.
    Possibly an inch/metric issue? What are the native units set to in Mach3, and is there a G20 or G21 at the start of the code?
    Jan 2007
    869
    Perhaps Surfcam is set at diameter based programming while mach3 is set at radius programming?
    I don't know Surfcam, but in my cam program I can set either radius or diameter based programming. I'm pretty sure that mach3 has somethin similar as well.
    Wade
  1. where to go to have MDF machined?
    By jerchi in forum DIY CNC Router Table Machines
    Last Post: 12-30-2009, 12:41 AM
  2. Via shape/size and wire size.
    By Drools in forum PCB milling
    Last Post: 08-14-2009, 03:47 PM
  3. Drawing Size and Cut Size Differ - Plasma
    By ADucci in forum LinuxCNC (formerly EMC2)
    Last Post: 10-05-2007, 10:52 AM
  4. Drawing Size and Cut Size Differ - Plasma
    By ADucci in forum Mach Plasma / Laser
    Last Post: 10-04-2007, 02:49 PM
  5. X3 base size or minium bench size
    By kenrc in forum Benchtop Machines
    Last Post: 02-04-2007, 01:50 PM
