586,111 active members*
3,724 visitors online*
Results 1 to 6 of 6
    Apr 2010
    cnc prgm for taper threads
    i need to make a cnc program for taper thread on fanuc series Oi Mate TC control.
    thread details are : 3/4" NGT Threads, Taper 1:16, Pitch 1.814
    a cnc program for this thread will be a big help
    thanks
    vikas
    Feb 2006
    1792
    I assume you want to make an external thread.
    Just give an R-value, with a negative sign, in G92, or in the secind block of G76.
    The meaning of R-word is exactly same as that of R-word in G90.
    While calculating R-value for G92/G76, consider the specified XZ location in the command block, and the start point of the cycle. Pull-out angle has no effect on this calculation.
    Apr 2010
    thanks for ur reply
    i would like to share that it is an internal thread
    and the tool is moving from large end to small end then how can we use negative value for R
    further i would also like to share that i have tried a prgm it worked but the quality of thread is not good though it confirms the gauges
    we can also say that the thread formed is very sharp
    i m sharing the prgm underneath for ready reference
    G28 U0. W0.;
    M01;
    T0101;
    G97 S1700 M3;
    G0 X20. Z50. M8;
    Z25.;
    G76 P040060 Q90 R0.03;
    G76 X23.5867 Z-25. P1161 Q150 R1.5625 F1.814;
    G0 Z50. M9;
    G28 U0. W0.;
    M30;
    kindly sugeest if any change to be made to this prgm
    thanks once again
    vikas
    Feb 2006
    1792
    For internal threads, R would be positive.
    Your rpm is too high.
    Initial bore dia may not be correct (it should be, OD - pitch of thread).
    Check root dia also (it should be, bore dia + 2 x depth of thread).
    Consult a handbook for depth of thread.
    Apr 2010
    pls let me know the correct rpm for this case
    regarding bore size, the plain plug gauge is being confirmed at both the ends
    as i have written earlier the thread is very sharp, which parametre should be altered so that desired results are achieved.
    as all the figures are calculated with formulas, only the X23.586 is the value i m not very sure off
    should i increase this value or decrease to reach the desired result, if yes how what variation should be brought pls tell
    and yes thanks once again for your response
    vikas
    Feb 2006
    1792
    Low rpm such as 500 may be used.
    X23.586 appears to be large. How did you calculate this value? Reduce it to, say, 19.5 and see what you get.
    How much is your bore dia?
  1. Cabinet CNC op / prgm -er saying hello
    By Mark Baratta in forum Community Club House
    Last Post: 10-26-2009, 06:31 PM
  2. NPT Taper-to-Straight-to-NPT-Taper Thread
    By bdyenter in forum MetalWork Discussion
    Last Post: 09-16-2009, 02:10 PM
  3. MORI LATHE SL NO Manual Coversational prgm
    By bobrob in forum Mori Seiki lathes
    Last Post: 07-24-2009, 03:34 PM
  4. Thread cutting prgm
    By barmilll in forum HURCO
    Last Post: 02-26-2009, 06:51 PM
  5. Replies: 6
    Last Post: 10-19-2008, 03:44 PM
