cut3d raster finish travel across part at z0, and another bug
Hey Guys,
Using cut3d, I need to machine a 2 sided part, to be exact, a heart, with a 2mm radius on the edges, from 12mm acrylic.
During the finishing pass, the raster generates a path that travels across the workpiece at z0, meaning that sometimes the tool will scratch the part.
Another strange problem is that sometimes the toolpaths are generated with several G2 moves, which mach3 seems to interpret as cutting large circles across the part or quite often hitting a limit switch.
Any solutions to both problems would be greatly appreciated.
Cheers
Ash
Machinists do it with greater precision and less tolerance!
