586,102 active members*
2,704 visitors online*
    Oct 2005
    378
    Poor Mans CNC Brake
    After looking at Big Toys press brake build I think he stole the show. I must say for a home build it is awesome. Some day I hope to own such a press brake but for now I will have to settle for my poor mans CNC brake.
    It is a 48" x 12 gage National finger brake converted to hydraulics. After setting it up it will repeat the same bend all day. I installed a cheap linear read out scale and an electrical switch for setting and controlling position.
    I also added a rotary encoder and a read out I bought off ebay for 75.00 for quick one off bends. The hydraulic system is single acting so I placed the counter weights on the handles to speed the return of the leaf after a bend. The handle valve on the stand ports to the oil tank when opened. When Making a bend I can crack the valve and "throttle" the speed down to a snails pace for better control.
    Magma-joe
    Attached Thumbnails Attached Thumbnails Brake 1.jpg   Brake 2.jpg   Brake 3.jpg   Brake 4.jpg
    Apr 2003
    550
    Quote Originally Posted by magma-joe View Post
    Magma-joe
    That is a super nice setup....
    Garry
    May 2004
    600
    You've acheived repeatable performance on a low budget setup. Nice work and well done!
    May 2005
    2502
    That's cool!
    BW
    Try G-Wizard Machinist's Calculator for free:
    http://www.cnccookbook.com/CCGWizard.html
  1. 600mm Box bend brake (Finger Brake, pan Brake)
    By RotarySMP in forum Bending, Forging, Extrusion...
    Last Post: 11-01-2015, 10:24 AM
  2. Poor mans XY table rails - would something like this be viable?
    By HankMcSpank in forum DIY CNC Router Table Machines
    Last Post: 08-31-2008, 02:14 AM
  3. My poor X1...
    By darkith in forum Benchtop Machines
    Last Post: 08-06-2007, 02:56 PM
  4. poor mans book
    By dragons_fire in forum Mini Lathe
    Last Post: 01-21-2007, 02:17 PM
  5. Poor Mans Autocad solid converter
    By CAMmando in forum Mastercam
    Last Post: 07-17-2003, 02:10 PM
