Hello,
I made some more progress with the B-C head assembly today and I came in feeling pretty good about the way it all went together so far. I got the head assembled to the carriage and the stepper motor mounted so the complete assembly is getting very close to a testing state in that all the mechanical aspects have come together very well.
The rotation is smooth both vertically and horizontally although there is a little work to be done routing the wiring and providing enough support and slack for the wires when in operation. That is something that will be more obvious and easier to plan for when the head is mounted to the gantry Y axis of the machine. The location of the mounting holes and positioning on the Z axis is the next probable step but I have taken some pictures of the head bolted to my surface plate in order to get some shots at different angles with the axis positioned to different angles. I have not powered the motors up yet and that will take a little work in itself as my current machine is using all 4 Gecko motor controllers just to operate the X, Y, and Z axis so I will need to add a couple more controllers and do some configuring and wiring as well as perhaps another break out board as I am not sure if my C10 will control 6 axis.
Here are the pictures of the assembled B-C head to show the state of the build at this point in time. In one of the pics my larger machine is in the background and that is the machine I plan on trying to test the head on.
Attachment 351136
Attachment 351138
Attachment 351140
Attachment 351142
