586,655 active members*
3,001 visitors online*
Page 1 of 9 123
Results 1 to 20 of 168
    Apr 2010
    Exclamation 5-axis (BC/AC) head construction
    Looking for not expensive way to construct 5-axis head.
    So need photos and drawing materials with internal kinematic
    plans to consider some real examples of commercial 5-axis
    heads like a TRI-TEACH, (not sure that Doughty Drive), etc.
    Please!
    If some own such compact (not heavy-duty heads),
    do a couple shots and sent it to me ..
    Thanks a lot.
    Attached Thumbnails Attached Thumbnails tilt-swivel-head.jpg   11.jpg   43087.jpg   TRITECHPMLTS8M.jpg
    Oct 2006
    975
    Hello Valio,
    I have been watching your thread here and don't see any responses so far. I am also working on a design to make a 5th axis head for my next CNC build. I started with a basic rectangular shape for the head but would really like to do something more like the Tri-Tech design with a more streamlined appearance.
    Maybe it will be good to start with the simple shape and then try to improve on it after it is done and I have a working prototype? Have you done anything with your design or started build it yet? If I get started on mine I will post pictures and details as I go with the build. Here is a snip of what I have drawn so far:
    Regards,
    Regards,
    Wes
    Oct 2006
    975
    Wow,
    I'm surprised there isn't more people interested in the construction and use of a 5th axis B/C head. I have seen a couple of 5th axis builds here on the zone but no in depth 5th axis B/C head ideas. Maybe the lack of reasonably priced 5th axis software does not help.
    Regards,
    Wes
    Jan 2006
    481
    Quote Originally Posted by metalworkz View Post
    Wow,
    have a look at this build http://www.cnczone.com/forums/showthread.php?t=98554
    cheers
    Apr 2009
    5516
    Wow,
    There is... we just keep it under wraps!
    Reasonably priced is a relative thing. If it's your livelihood, you'd factor in the return on your investment; also some software vendors provide financing, but most likely mainly to corporate or business accounts. If it's just your hobby, well then you need deep pockets!
    Oct 2006
    975
    Quote Originally Posted by louieatienza View Post
    Hello Louie,
    I am looking to make the 5th axis for my next hobby CNC machine, so it would help to have deep pockets but that is not so in my case. If I had deep pockets I would simply purchase something available like say one of the Doughty B/C heads. I will just have to design and build my own along with the CNC router/mill in about a 48" x 48" size. I had other ideas regarding the design of the machine itself to perhaps enable a smaller footprint machine to do larger work but have not decided which way I will go with it. I have the bulk of a small B/C head designed from scratch so I will just need to start cutting the parts and see if it all works out. I will probably see about getting the B/C parts drawn in inventor so I can better see how it will work.
    I have kept my intentions to build the 5th axis mostly to myself also but I figured there isn't a better place to network these ideas and see what the rest of you are doing along these lines. Thanks for replying to the thread, and I hope some more people will respond with their ideas and advice.
    Regards,
    Regards,
    Wes
    Apr 2009
    5516
    Hey Wes...
    I have a few drawings of ideas for a B/C head. I would like to contain either my steppers or servos within the unit itself, so it's not sticking out in the way, and use timing belts for gear reduction/turning each axis. Only thing is, I'd have to make the gantry tall to accomodate everything, as well as keep the Z stiff enough with the longer length...
    Oct 2006
    975
    Hi Louie,
    That is the way I have mine designed so far also(motors enclosed inside the head and belt driven) It will required a tall Z as you have mentioned, but the tall Z will also allow machining of taller items. I wonder if the location of the motors can be changed to reduce the height some for the Z axis? The placement of the motors in my current design is more of an inline design and the location of the motors may be modifiable to reduce the vertical height? I would have to look into the interference fit for all the parts to make sure it will not inhibit the angular travel of the head. I think for my first 5th axis I may just use my original design and make changes after the prototype is done. I would rather have a good functioning head at that point but am willing to make some changes to better the design while being able to actually test it. I was thinking of a .25" thick aluminum construction but a .125" 6061 AL will probably be thick enough and I can add some gussets if needed to beef it up.
    Regards,
    Wes
    Oct 2008
    199
    Hi Guy's
    I'll share the head I've been working on.
    Although still not completed and tested, it's well underway.
    Louie, You'll be happy to see the steppers contained within the unit, 50:1 harmonic drives are used for reduction. Using these drives makes packaging very straight forward, Prurchased secondhand off ebay for around US$90 for the pair. (the internal bearing of the drive is not shown in the photos)
    I've spent about a weeks labour putting it together and now only needs shortening of the two axis to make it more compact.
    130mm aluminium solid bar was used.
    THK crossroller bearings cost nearly Au$500 ea.
    350 oz-in steppers housed within and may need some form of cooling fan attached to the housing, although the housing will work as a great heatsink.
    Hope this gets the creative juices flowing for you!
    I haven't attached photos before so here go's
    Liam.
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    I've since changed the way it is assemble since this photo was taken to the above but it does show the second rotation that isn't shown in the above
    [IMG][/IMG]
    Oct 2006
    975
    Hi Liam,
    Wow, that is a very impressive 5th axis! I will not be attempting anything that large now, and will have to keep mine as light as possible. Your machine must be a bit more industrial strength and size than what I had planned for mine. Thanks for posting your pictures and info, and please do keep us updated on your progress.
    Regards,
    Wes
    Oct 2008
    199
    No worries and thanks for the compliments.
    obviously this concept could be downsized for a smaller machine.
    Also to minimize Z height my 4th axis stepper resides within 150x150RHS Z axis column.
    I may be bias but i think the harmonic drives are the way to go if had for the right price.
    happy building
    Heres a link to the build thread for some background info
    http://www.cnczone.com/forums/showth...ybrid&t=101936
    Apr 2009
    5516
    Wow Liam that's radical! You building a VMC?! Excellent work...
    I'm not too familiar with the harmonic drives but that may b e the way to go if I can score some cheap enough...
    Sep 2005
    1195
    Any body here know the price for 5 axis tritech, doughty or colombo? Please share. Thanks.
    Oct 2008
    199
    VMC
    doughty are around $2000 for the complete setup...give or take a couple of hundred.
    Oct 2008
    199
    HSD 6.5kw head 90kg and an asking price of around 100K
    anyone with some good ideas....different gear reduction, cable routing,limit switches etc for b/c heads?
    I searched the forum for ab, bc for hours with very little result when I started building mine.
    Bartus has used automotive bearing assemblies in his machine...very affordable
    Sep 2005
    1195
    Wooow, very expensive. I thought its below 10K usd. I will do it Bartus way in the future, it looks like affordable. Thanks.
    Oct 2008
    199
    the trouble with using the automotive bearings is that a bearing is required on both sides of the spindle and this eats up the Z axis height.
    This was my main reasoning in spending up big on good quality high precision bearings.
    Oct 2008
    199
    Chad's machine from the artsoft forum
    I'm not sure but it looks like he's used indexing heads from a mill or at least used the idea for inspiration.
    also here is a link to the harmonic drrive actuators, I f i had my time again.....these are WAY too cool
    http://www.harmonicdrive.net/products/actuators/
    servo, reduction and bearing all in one, would make an amazingly compact design.....hate to think of the price though (nuts)
    Oct 2008
    199
    http://www.cyber-cnc.com/rotary_indexing_tables.html
    Check out this stuff from India, Specs look good
    Might be a lot cheaper coming from India also.
    Oct 2008
    199
    There's a doughty setup in the zones clasifieds if anyone is interested
    http://www.cnczone.com/classifieds/s...p?product=3970
Page 1 of 9 123
  1. Steel Base 3 axis (phase 2: Construction)
    By Tadas25 in forum DIY CNC Router Table Machines
    Last Post: 04-03-2014, 06:48 AM
  2. Axis construction ideas (low money)
    By ob38 in forum CNC Wood Router Project Log
    Last Post: 08-06-2012, 09:34 PM
  3. Two different approach for Z axis construction
    By turpija in forum DIY CNC Router Table Machines
    Last Post: 11-06-2007, 12:05 AM
  4. construction started with the Z axis last night
    By broncosis in forum CNC Wood Router Project Log
    Last Post: 08-07-2004, 02:21 PM
  5. construction started with the Z axis last night
    By broncosis in forum DIY CNC Router Table Machines
    Last Post: 06-16-2004, 07:19 PM
