586,913 active members*
2,778 visitors online*
Hybrid View
    Apr 2010
    Exclamation Conquest T-42 Hydraulic
    This morning is started up T-42 lathe to continue with Fridays set-up and after having the machine on for about 45 mins it went into E-Stop mode n came up with the error 1000 OVL (OL-1,OL-4).(nuts)
    In my Hardinge maintenance book it says that OL-1 is hydraulic motor overload on contactor tripped. It also says OL-4 is hydraulic heat exchanger overload on contactor tripped.
    So with that being said has anyone had a similar problem or can suggest an approach to trouble shooting my problem. Any response is greatly appreciated.
    Thanks, imac.
    Oct 2005
    118
    Try opening your electrical panel around back with the power off and reset the contactor. Off hand I don't remember which one it is. They use AB contactors which are usually have a small button to reset them.
    Apr 2010
    Quote Originally Posted by Janos View Post
    Thanks for the response, I've tried this and it doesn't seem to want to reset itself. Keeps tripping. So maybe it is a bad switch, or motor. Either way its bad timing as this is the only lathe i have with live tooling and a huge job list for it.
    Apr 2010
    Hey after reading your suggestions i found a reset of one of the contactors that was tripped that i could reset and now everything is working good. Thanks again for your help.
  1. Conquest 250
    By wbp in forum CNC Machining Centers
    Last Post: 06-19-2013, 02:36 PM
  2. Hardinge Conquest 42
    By newc in forum Hardinge Lathes
    Last Post: 02-25-2010, 01:10 PM
  3. adjusting the turret on Conquest 42
    By dango in forum Hardinge Lathes
    Last Post: 11-05-2009, 04:41 AM
  4. Hardinge Conquest 42
    By cncdiag in forum Fanuc
    Last Post: 05-21-2008, 01:06 AM
  5. Hardinge Conquest ST-25 problems
    By jasper2245 in forum Bridgeport / Hardinge Mills
    Last Post: 02-08-2008, 05:18 PM
