586,077 active members*
3,926 visitors online*
Results 1 to 7 of 7
    Jul 2004
    442
    Sanyo denki encoder
    I have a servo with a sanyo denki encoder, 15 years old.
    I had this working at one time and I remember it needed a couple 1000 ohm resistors in the scheme. Unfortunately I no longer remember the wiring. Can someone help.
    Thanx,
    Ozzie
    24221
    Can you identify any of the wires? The resistors were probabally pull up from A & B to 5+vdc.
    If it was a couple, then most likely a single ended encoder, 4 wires or 5 max if marker also?
    Al.
    Albert E.
    Jul 2004
    442
    Yes thanks Al,
    All wires are identifiable. Only used 4 last time -, +5, A,B.
    So you think from +5 to A through resistor
    Same for B ???
    24221
    I am just guessing, but if there are only A & B output, (not differential) then the odds are it is open collector and this was the reason for the pull-ups.
    If so then 1k on each A & B to 5vdc.
    This was often a common arrangement on the smaller S.D. motors.
    Al.
    Albert E.
    Jul 2004
    442
    I don't have them right here in front of me, but there are other wires. I know one says C.
    But I've used them with Mach 3, and Gecko drives, using A and B. They're nema 34, about 600 W.
    Ozzie
    24221
    C could be the the marker pulse, as in A B & C?
    You can always try them without the pull-up if the transition voltage does not go from 0 to 5v on the A & B, then use a pull-up resistor.
    Al.
    Albert E.
    Jul 2004
    442
    Thanks again Al, all together and working.
    Ozzie
  1. Sanyo Denki Help
    By Gary D in forum Stepper Motors / Drives
    Last Post: 06-30-2012, 06:10 AM
  2. Sanyo denki P5
    By virgoviggo in forum Servo Motors / Drives
    Last Post: 01-23-2011, 05:37 AM
  3. Sanyo Denki Drive
    By RAC in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-21-2009, 05:09 PM
  4. Sanyo Denki 65BA030VXT01
    Last Post: 05-09-2008, 09:22 PM
  5. G20 and Sanyo Denki Super-U
    By happytriger2000 in forum Gecko Drives
    Last Post: 05-20-2007, 01:24 PM
