There is probably a simple answer to this, but it is eluding me
I have installed the proper 120VAC relays on the 1100-1D board to use the USER M functions (M60-69). I am trying to get a response from the M60/61 relay. I have installed the fuse, the jumper to get the 120V supply to the relay as outlined in the (March 03) Maintenance Manual, section 9, page 341. I have a light bulb wired to the output just to see if I can get it to switch on and off.
But no such luck.
When I manually input common M codes such as M7,8,9, I get the code listed in one of the middle "active code" box on the screen showing that code as active. I don't get any such indication that the code is active when I input M60-69.
Is there a setup or command variation that I am not doing right?
Thanks in advance for any help!
Robert Paisley
2000 VMC3016
Upland, CA
