586,105 active members*
3,248 visitors online*
Page 1 of 29 12311
Results 1 to 20 of 569
    Aug 2009
    899
    RF-45 CNC Advice needed
    So after having the X2 CNCed for a year now I need something bigger. I have decided to go with the RF-45 and I want to do it right this time. I am looking at the Keling KL34-180-90 1125oz Servo motors, the Gecko G320X Drivers, CNC4PC C11G breakout board. but I'm not sure on what else I will need for electronics. Do I need encoders? Would it be better to use Stepper motors?
    Oct 2007
    398
    I have the Keling 1125 in-oz servos, though they have not been mounted yet. They are probably overkill for the 45, but they will do the job. I don't know if steppers would work well on this machine. To get the power up you will need to go with bigger and slower motors which could be annoying with the long x travel IMO.
    You need encoders. I'm using (hopefully) the US-Digital encoders Keling sells, but they have quite the bad reputation on this board. It has an unusually low current draw making it difficult to noise proof. There is another encoder Digikey sells that gets more respect, but I forget the name.
    You will also need a power supply. This is what I bought - after reading that others were using it.
    There are a ton of RF-45 threads gong right now. This one and this one have some good info on motors and encoders.
    Jeff
    Aug 2009
    899
    Awesome so servos it is, I found the Digikey encoders 102-1307-ND. What ball screws and ball nuts did you go with?
    Oct 2007
    398
    I bought ball screws from linearmotionbearings on ebay. The seller has a good reputation on this board, and more importantly his ball screws are super cheap! I plan to machine the ends myself, but he does offer custom machining at reasonable prices. These are rolled C7 screws, BTW. There are definitely higher quality alternatives if you are willing to pay more.
    Dec 2009
    303
    RF-45s
    Quote Originally Posted by eartaker View Post
    What Jeff said
    I also picked up ballscrews from linearmotionbearings2008 from ebay.. haven't tried them / measured them for error/backlash yet though. i also picked up their bearing blocks (only bought one side/ the motor side).
    The CUI AMT-102V encoders work really well.
    I'd take a read at Bob W's electronics page: http://www.cnccookbook.com/CCMillCNCElectronics.html
    Getting set up to get the motors working is reasonable, but i'm in the phase of getting everything up to safety and for monitoring - I bought the Master Control Board from CNC4PC - the C17 board.
    Which computer cpu are you going to be running off of? and are you planning to use the printer port? A lot of people have been going USB via the SmoothStepper (not a lot of documentation on the site: http://www.warp9td.com/ ), if you want to go laptop or get a higher pulse rate going..
    Aug 2009
    899
    I have been using the parallel port with my X2 but will probably go USB. Not sure on the computer yet ill throw another one together. might go with a mini ITX 2Ghz dual core so i can put it in the controller box. I have looked at this supplier for ball screws but what size and pitch did you go with?
    Dec 2009
    303
    hey eartaker,
    I went with 20mm ballscrews at 5mm pitch for all axis' (some would consider 25mm for Z). the end blocks (2 a/c bearings from what i know) are 15mm and the finished ends for the pulleys are at 10mm
    matt
    Apr 2007
    2580
    Sounds like my setup......
    That is basically what I am using, Antek multi voltage power supply, CNC4PC C11G breakout board, Three G320's, The AMT encoders( WHICH ARE AWESOME), And some Keling INc. 1125 oz inch motors. Mine is very powerful with this setup and has worked well despite my hamfisted attempts at blowing stuff up and crashing things into other immovable things it continues to amaze. I get some decent rapids( I actually turn it down to be a little safer) and there is more than enough power on tap to break endmills without a seconds thought. I did manage to blow up two geckos along the way but that is my inexperience talking and not any fault of the setup. I do not see how you can go wrong with this.....
    You will really love the servos, they are amazing and nearly silent in operation, and once I got my steps per right I am getting some very accurate results for a homebuilt machine. I do recommend a slightly higher ratio for the Z axis and when you are in there make every effort to lock down the Z axis slide to the ballscrew mount. I did the mods that IH recommends and even went a little further, you can see what I did on my build thread. There is some difficulty getting the Z tight due to it's weight and I used a 3/4 inch ballscrew on the Z just to be sure. I used 5/8 inch screws on the X and Y and they are more than adequate for the size of this machine. When you make the Z top motor mount make sure you leave enough meat below the angular contact bearings to take the constant lifting of that heavy head. I chose to make all of my mount plates from 3/4 inch aluminum and the bearing pockets are not that deep so no worries.... The funny thing is none of this is hard to do but if you do not get all of it right you will be chasing little fidgety bull**** forever..... Do it right the first time and take your time. Also I HIGHLY recommend doing the one shot oiler setup with at least a manual pump. It makes a world of difference in the operation of the machine and allows you to run your gibs a little tighter.
    If you are gonna run flood coolant like me I took a page from the IH setup with running the wiring inside surgical tubing and route everything with brass hose barbs. This is a real good idea and makes another little thing less of a worry, chafing on the wires from the machine running back and forth constantly is much improved. Another thing I recommend is take the time to finish your limits and homes if you intend to use them before you start running the machine, if I did that I would not have burnt out that gecko. I understand you already have a cnc mill so that may not really apply to you depending on your confidence level.
    These are wonderful machines and at this size capable of some real metal removal. You will be pleasantly surprised for sure..... Good luck and if I can help you don't hesitate to ask.... peace
    Pete
    Aug 2009
    899
    Well Pete your Post on your ZX45 is where I got the ideas for what parts to use =]
    Thanks for all of the input. I have ordered the motors and encoders. I went to place the order for the Gecko G320X's but they are out of stock. I will call them today. Hope they will have them in soon. I guess the only part I'm still in the dark about is the breakout board. The C11G looks good and has a built in charge pump. I eventually would like to fully automate the spindle control. I have also been looking at the smoothstepper board with the C25 breakout board. Witch one of these would you suggest? Also what would I need to automate the spindle control? I have seen that some have used with C6 board with the C3 on the X2's but I'm guessing I will need something to drive a VFD for the RF-45.
    Jermie
    Dec 2009
    303
    Jermie
    Hi Jermie,
    Where did you try and order the Geckos? If from Gecko directly, try KelingInc.net. if you're looking at the smoothstepper, from what i know the c25 is what most of us have. i bought the c6 to do spindle control and a teco 7300cv VFD (for a baldor 3hp 3 phase motor).. c15 for coolant control.. these are all still sitting idle as i finish the main cncing of the machine..
    Matt
    Oct 2007
    398
    Funny, I'm pretty sure the G320x's I ordered from Keling were drop shipped from CNC4PC. Not sure if that's the normal procedure for Keling. They were missing from a larger shipment, and I had to ask for them before they were shipped.
    Jeff
    Aug 2009
    899
    I tried ordering from Gecko, I guess I will have to call Keling and modify my order b4 they ship it.
    Aug 2009
    899
    Well i didn't get ahold of Keling in time but they did say they would give me the discount for the drivers as if I would have placed it in 1 order. Some fast shipping on their end. So the Gecko G320X's are on there way. I have about 3 months to plan this build before I even get to touch the equipment I am buying so it should go smooth hopefully. For the large debate... what RF-45 cloan to go with...
    Apr 2007
    2580
    Jeremie....
    If you decide to get the CNC4PC C11G board, that is all you will need unless you want the smoothstepper. The C11G board is what I am using and it will literally control everything you need for the machine. It has on board spindle control for speed and direction that will integrate with the VFD( mines a teco sensorless vector drive and I really like it) and uses a step and direction signal to control things with mach3. It also has on board multiple solid state relays and can control your coolant and other peripheries... Mine has been rock solid since I got it wired right and I have had NO issues.... It is also very nice to have everything in one board, makes wiring less complicated even for someone like myself who knows not what the hell he is doing generally.....
    I would highly recommend getting the G320X from Gecko directly since from what I understand the reason they are out of stock is because they are preparing to release their newest version of the 320X which includes anti dithering and other advanced features. They are supposed to be in very soon.... If you do decide to use the Gecko 320X, I HIGHLY recommend the AMT encoders, they were what Mariss personally recommended to me over the phone and I can see why....
    Just a word on Gecko drives..... I have to say that in my cnc adventures I have managed to fat finger and otherwise ham fist my wiring at every turn due in large part to my inexperience with cnc and building my own controller. In that time I have managed to fry two drives, one of which was replaced at no charge from Geckodrive. The other one was not repairable. They were kind enough to offer me a refurbished drive at a reduced cost to help me get back running again. Most recently I got back from vacation and found my Y axis was making a funny noise. I poked around until I realized that my Gecko was the problem. I removed it, sent it to Geckodrive, and they were able to repair it. I got a phone call today from their very friendly secretary letting me know it was repaired and was shipped out today ground. I was very pleased and when I asked what I owe them, she said nothing!!! She said it was a service they provide to their loyal customers..... I was dumbfounded!!!! I thought, perhaps they would repair it for cheap or free but surely I would have to pay the return shipping..... NOPE< they took care of everything!!!! That my friends is what you call exemplary service.... I am a customer for life now.... nuffsaid....
    peace
    Oct 2007
    398
    If you're looking at ITX boards and want to try doing without the Smooth Stepper, the D945GSEJT has an on board PP that "should" work just fine. I have one, but haven't tested the PP with the G320x's or the C11 board. I just haven't had the time to finish wiring my G320x's, but maybe this weekend...
    Aug 2009
    899
    Pete,
    Sounds like the C11G is the way to go for me. 3 Axis control with spindle and coolant.. I need nothing more than that. What board are you using to feed the spindle speed into Mach 3? The C6? I have already placed the Order with Keling for the G320X's guess I could have held out on that since I wont be home for another 3 months.
    Flenser,
    I like the cost of that board but I think I have one here that I will be using made by dell.
    I cant wait to get home and start working on this. Will be an awesome gift/project for myself after being here in Afghanistan. Would you suggest the ZX45 from Bolton over the other brands such as IH or Lathemaster?
    Oct 2007
    398
    I bought the Bolton strictly for the price. I got a much lower price due to a (probably mistaken) Amazon deal they have since modified. The IH, Lathmaster and Grizzly machines probably have better quality control.
    Aug 2009
    899
    I have been looking and debating and still cant make up my mind. Do any of the 45 Cloans come with ball screws pre installed?
    Apr 2007
    2580
    Jeremie....
    Hey man perhaps I was not clear, the C11G board basically already has the C6 spindle board on it..... you do not need any further boards.... I know that I can install a sensor on the spindle to have feedback to the computer but I have not gotten that far quite yet. Right now I have it calibrated to return the proper spindle speed to what is keyed in and it is pretty close. It took some fidgeting to get it there tho......
    As far as the best milling machine to purchase, if you have the cash, the IH machine is larger in the travels and slightly heavier than most of the RF 45 machines. You can buy it direct from IH or from the canadian machine tool dealer whose name escapes me right now.... If you have the cash I would probably go that way as you would end up with a larger machining envelope which is very desireable. If you do not then I would take your pick of the rest of the suppliers, I bought mine from Lathemaster and it has been a good machine but I understand he is waiting on shipment for new machines right now( not completely sure about that, you might wanna call him to check) He is a very nice fellow and has taken care of me long after the sale.... The machine Hoss bought also looks nice and to be honest while they are all basically the same I would try to buy the one that gives the best travels..... My Lathemaster is an early model and the millhead has the larger Z slide similar to the IH machine whereas the vast majority of the machines available now have the smaller ring on the Z slide.....
    Good luck with whatever you buy and be sure to post a build thread when you get back home. If you are a servicemen fighting for our country let me first say THANK YOU FOR YOUR SERVICE as for myself and my family it is certainly appreciated.... Please be careful over there...... Peace
    Aug 2009
    899
    Thanks Pete, it is much appreciated. I am in the Army and hope to be home soon and safe.
Page 1 of 29 12311
  1. advice needed
    By teamjnz in forum Haas Lathes
    Last Post: 05-20-2009, 11:19 PM
  2. Advice needed.
    By Terence E in forum Community Club House
    Last Post: 05-14-2009, 03:56 PM
  3. advice needed / to buy or not???
    By teamjnz in forum Uncategorised MetalWorking Machines
    Last Post: 08-27-2008, 02:48 PM
  4. advice needed
    By trubleshtr in forum CNC Machine Related Electronics
    Last Post: 04-22-2005, 02:48 AM
  5. Little advice needed
    By STUG in forum DIY CNC Router Table Machines
    Last Post: 01-26-2005, 02:11 AM
