586,103 active members*
2,878 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > 197 C-AXIS COMMANDED IN SPINDLE MODE
Results 1 to 9 of 9
    Mar 2006
    107
    Machine is lathe Romi G15SM
    Control Fanuc 18i-TA
    Alarm: 197 C-AXIS COMMANDED IN SPINDLE MODE
    Here is whole program.
    Machine stops and alarms at point "PROBLEM" in red color.
    When machine reads this line "G0 X0", in DISTANCE TO GO there is value for X and C. Obviously it thinks it is still in circular interpolation?!
    Anyway, I have to push RESET, go to line "(CENTER DRILL 8 TM)" and than run program.
    There is same thing lower in the program (C-mode with circular interpolation and spindle mode after it), but there is no problem, no alarm.
    I attached M-code list of machine.
    O0680 (PLATE-BRNO550-FIX-1)
    G90 G40 G18 G54
    T0004 (LONGEST)
    G0 Z20
    (PULLER)
    T0808
    G94 F3000
    G0 X30
    G0 Z-20
    M45
    M3 S20
    G4 P4000
    M5
    M46
    G1 X0
    G4 P2000
    M24
    G4 P2000
    G91
    G1 Z9.4
    G90
    G4 P2000
    M25
    G4 P2000
    G1 X30
    G0 Z2
    T0004 (LONGEST)
    G0 Z20
    (TURNING)
    T0101
    M45
    G95 F0.08
    G96 S100
    G92 S3500
    G0 X18
    M4
    G0 Z0
    G1 X-2
    G1 Z1
    M5
    M46
    T0004 (LONGEST)
    G0 Z20
    (CUT OFF 2.2)
    T0202
    M45
    G95 F0.1
    G92 S3000
    G96 S50
    G0 X18
    M3
    G0 Z-9.1
    G1 X8
    G1 X18 F0.5
    G0 Z2
    M5
    M46
    T0004 (LONGEST)
    G0 Z20
    (END MILL 12)
    T0606
    M45
    G97 S2000
    G94
    G0 X50
    M16
    M19 (C-AXIS ON)
    G28 G91 G0 C0
    G0 G90 C0
    G0 Z2
    G12.1 (CIRCULAR INTERPOLATION ON)
    G42
    G1 X-10.3 C12 F5000
    G1 Z-7.5
    G1 C0. F200
    G3 X10.3 C0. R5.15
    G1 C5.55
    G3 X8.9 C6.25 R0.7
    G1 X-8.5
    G3 X-9.9 C5.55 R0.7
    G1 C0.
    G3 X9.9 C0. R4.95
    G1 C5.55
    G3 X8.9 C6.05 R0.5
    G1 X-8.9
    G3 X-9.9 C5.55 R0.5
    G1 C4.55
    G2 X-23.9 C-4.989 R10.
    G1 Z2 F5000
    G40
    G13.1 (CIRCULAR INTERPOLATION OFF)
    M18 (C-AXIS OFF)
    M17
    M46
    M5
    T0004 (LONGEST)
    G0 Z20
    (CENTER DRILL 8 TM)
    T1212
    M45
    G95 F0.04
    G97 S2500
    G0 X0 (PROBLEM)
    G0 Z1
    M3
    G1 Z-3.6
    G4 P500
    G0 Z2
    M46
    M5
    T0004 (LONGEST)
    G0 Z20
    (DRILL 4 HSS)
    T1111
    M45
    G97 S2500
    G94
    G0 X0
    M3
    G0 Z1
    G1 Z-9.2 F110
    G1 Z2 F5000
    M46
    M5
    T0004 (LONGEST)
    G0 Z20
    (END MILL 7)
    T0404
    M45
    G97 S2500
    G94
    G0 X0
    M3
    G0 Z1
    G1 Z-3 F50
    G4 P500
    G1 Z2 F1000
    M46
    M5
    T0004 (LONGEST)
    G0 Z20
    (CHAMFER MILL)
    T1010
    M45
    G97 S2000
    G94
    G0 X50
    M16
    M19
    G28 G91 G0 C0
    G0 G90 C0
    G0 Z2
    G12.1
    G42
    G1 X20 C6.05 F5000
    G1 Z-4.5
    G1 X-9.9 F200
    G1 Z-3.5
    G1 C0.
    G3 X9.9 R4.95
    G1 C12
    G1 Z2 F5000
    G40
    G13.1
    M18
    M17
    M46
    M5
    T0004 (LONGEST)
    G0 Z20
    (CUT OFF 2.2)
    T0202
    M45
    G95 F0.1
    G97 S2000
    G0 X18
    G0 Z-9.1
    M3
    G1 X-1
    G1 Z-8
    G0 Z2
    M5
    M46
    T0004 (LONGEST)
    G0 Z20
    M99
    Attached Files Attached Files
    Sorry for bad english
    Aug 2008
    406
    I dont see a M43 C axis connect......
    Mar 2006
    107
    Quote Originally Posted by gabedrummin View Post
    I think this is not used on my machine...
    For M43 manual says "Chuck Clean Off".
    I have done pretty much programing (cutting) with C-axis since now, always using same principle, and never had problem like this.
    Jun 2007
    119
    try to put M3 before G0 X0 (PROBLEM)
    Mar 2006
    167
    Looks ok to me. My only question would be is the line definitely G0 X0 and not C0 X0 in the machine?
    Mar 2006
    107
    Quote Originally Posted by viorel26 View Post
    Tried this before and now again, doesn't help.
    Quote Originally Posted by Ozemale6t9 View Post
    It is G0 X0 for sure. In other case, when I push RESET and continue program from this tool, at line (CENTER DRILL 8 TM), it would alarm again.
    But when I do that program runs OK.
    Mar 2006
    107
    Any other ideas?
    I have tried to put G1 X0 F1 instead of G0 X0 but no help.
    I tried to put some other value for X different than 0. No help.
    In every case when machine reads this line in Distance to go there is value for X and for C. And alarm.
    After pressing OK and starting program from this line again, everything is OK... until it comes to this line again (after one cycle).
    Feb 2006
    1792
    When you get the alarm, is G13.1 active?
    Mar 2006
    107
    Quote Originally Posted by sinha_nsit View Post
    Very good question. I have not checked it before.
    Now I see that G13.1 IS ACTIVE when I get alarm.
    It means that circular interpolation is CANCELED.
    So why it wants to move "X and C" when I give X...
  1. PMC-ALARM 202 "Commanded Tool in Spindle"
    By moldmker in forum Mori Seiki Mills
    Last Post: 04-23-2009, 04:58 AM
  2. Bridgeport EZTRAK Alarm: commanded X-axis move too far positive
    By Pribbs in forum Bridgeport / Hardinge Mills
    Last Post: 01-23-2009, 03:34 PM
  3. Alarm: commanded X-axis move too far positive
    By JonMatear in forum Bridgeport / Hardinge Mills
    Last Post: 08-06-2008, 02:41 PM
  4. parser: commanded z axis move to far possitive
    By tonymann in forum Bridgeport / Hardinge Mills
    Last Post: 11-10-2007, 06:05 AM
  5. Replies: 14
    Last Post: 01-08-2007, 06:10 AM
