Originally Posted by
zax15uk
Rich,
Here are my 'standard' settings, although it varies based on the image and the material:
Mode: 2 lines enhanced (these options set the screen preview only and do not effect the output)
Scan gap: 0.1mm = 254dpi
Speed: 10cm/sec
If you only have a small input image it may be necessary to use 0.2mm = 127dpi or lower. This can still produce excellent results, especially on tile or harder materials where the fracture site is larger. Higher dpi does not always result in a higher perceived resolution of the final engraving.
Zax.
