586,103 active members*
3,534 visitors online*
    Oct 2009
    16
    parallel port
    Hello, my computer has no parallel port, may I use the serial ->parallel port adapter by using Mach3? Thank you!
    Apr 2009
    144
    I don't think you can use an adapter like that as a standard serial port has 9 pins an the parallel port has 25 and you need most of them.
    I had the same problem as you, so I got a PCI parallel card. I initially got one made by syba, but it would not work. Then I got one by startech and it works just fine.
    The only problem is that the "charge pump" does not work with this PCI card.
    Based on what I've read, the charge pump doesnt work with any PCI card
    http://ncix.com/products/?sku=48537&...tech.com%20Ltd
    JGRO Complete - G540, 380oz Nema23s, 1/2-10 ACME, 30"x14", Craftsman router
    Joes 4x4 R&P in progress
    Oct 2009
    16
    I see, thanks.
    BTW, what is the different of your 2 PCI boards?
    Apr 2010
    14
    you can use the db9 with deskcnc
    www.deskcnc.com
    I have used deskcnc often and is very simple
    joe
  1. USB to Parallel port??
    By willio in forum Shopmaster/Shoptask
    Last Post: 11-12-2009, 09:42 PM
  2. parallel port or parallel universe
    By bruno34 in forum Taig Mills / Lathes
    Last Post: 04-15-2009, 04:58 PM
  3. Where's the parallel port?
    By cdlenterprises in forum Mastercam
    Last Post: 01-21-2007, 12:23 AM
  4. 2nd PCI Parallel Port
    By sunmix in forum Mach Software (ArtSoft software)
    Last Post: 11-22-2006, 09:17 PM
  5. Second parallel port?
    By essa in forum LinuxCNC (formerly EMC2)
    Last Post: 04-12-2006, 08:18 AM
