586,114 active members*
3,207 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > Waterjet General Topics > Plasma bevel cutting burny 10LCD+ code inside
    Apr 2010
    Im a new cnc operator, and I could use some pointers.
    I have a burny 10lcd+, alltra, hypertherm 260.
    I know its not specific, but I can get more info tomorrow.
    I have sorta 'jury-rigged' some code and it kinda works; but I could really use some help here. Im also having trouble with my hypertherm settings. Before I went home I cut a pretty nice looking 6" x 6" plate outta 3/8 MS.
    Where can I find a list of G-codes and/or M-codes for my machine.
    I have a list from my old burny 3 and 'some' of them are the same; but I need help.
    The first time I ran this code it did really good, but I tried it again and the head kept crashing. Im not using a bevel set-up. Im just using the same set-up that I use for cutting 3/8 CarbonSteel. ie.. 130
    I have a 260 and 130 setup/tip. But I only use 260 for stuff larger than 7/8"
    Also, what about the math,, my square is not square, because it is not accounting for the torch tilt so it adds an extra 1.5 inches to the X-axis.
    Do I just subtract 1.5 inches ,,surely that will work.
    M285 <--LASER OFFSET
    G70 G91 X6.3535Y0
    G97
    G41
    M04
    X-.3535Y-.3536
    M306 <----- TILT HEAD +
    G04F1 <--- PAUSE 1 SECOND
    M14 <---DISABLE AHC, SO THAT i DONT GET BOUNCING HEAD
    Y-6 <--6 INCHES Y
    M304 G04F1 M15 <--AHC ON FOR REGULAR CUT
    X-6 <-- 6 INCHES X
    G04F1 M307 <-- TILT HEAD -
    G04F2
    Jan 2008
    2247
    Contact Burny and they can provide you a listing of all of their machine codes.
    Jim Colt Hypertherm
    Dec 2021
    Quote Originally Posted by MrElder View Post
    G70 G91 X6.3535Y0
    G97
    G41
    M04
    X-.3535Y-.3536
    Y-6 <--6 INCHES Y
    X-6 <-- 6 INCHES X
    G04F2
    Change your kerf value
  1. Replies: 0
    Last Post: 12-03-2010, 05:47 PM
  2. Plasma bevel cutting
    By jgramlich in forum Waterjet General Topics
    Last Post: 05-27-2010, 02:54 PM
  3. Komatsu fine plasma profile cutting G code
    By nguyenthanhthi in forum G-Code Programing
    Last Post: 03-06-2009, 12:50 PM
  4. G-Code for bevel cutting head
    By Franz Grueter in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-18-2009, 02:21 AM
  5. Plasma Bevel
    By pricer in forum Waterjet General Topics
    Last Post: 06-19-2007, 03:05 PM
