586,635 active members*
3,005 visitors online*
    May 2005
    7
    Exclamation Programming Okuma LT300 with Sub Spindle
    Hi all, Just had an Okuma LT300 for a month now, having alot of problems getting the P coding right to syncronise the twin turrets etc. Does anybody have some experience with this type of machine on this forum?
    ANY help would be appreciated.
    many thanks,
    Simon B.
    London, Ont.
    Canada.
    16
    Hi (okuma twin turret )
    HI
    HERE IS THE TWIN TURRET PROGRAMME.DONOT RUN THIS PROGRAMME.JUST EXAMPLE ONLY TRY TO EDIT YOUR PROGRAMME AS LIKE THIS P NUMBERS.I PUT SOME EXPLANATION IN BRACKETS .
    ANYTHING ABOUT OKUMA LATHE PLS SEND MAIL TO ME I WILL SOLVE THE PROGRAMME AND SEND IT BACK TO YOU.MY MAIL ID IS [email protected].
    GOOD LUCK
    N0001G13
    (PROGRAM USING TWO TURRETS)
    CLEAR
    DEF WORK
    PS LC,[-15,0],[15,13]
    PS LC,[0,0],[07,81]
    PS LC,[07,0],[20,25]
    PS LC,[27,0],[06,46]
    PS LC,[33,0],[10,13]
    END (DO NOT RUN THIS PROGRAMME IT IS AN EXAMPLE ONLY)
    DRAW
    N20G14
    N30G0X30.Z20.
    N40G50S1800M59
    N50G111
    N60G13
    N70G0X24.Z12.
    N80G50S1800M59
    N90G13
    N100T0404P180( P MUST BE SAME IN 'B' TURRET)
    N110M08P190 (P MUST BE SAME IN 'B' TURRET)
    N120M42P200 (P AND RPM RANGE MUST BE SAME IN 'B' TURRET)
    N130G97S450M03P210 (P AND RPM MUST BE SAME IN 'B' TURRET)
    N140G0X0.Z5.
    N150Z4.177
    N160G95
    N170G1Z3.577F.004
    N180G0Z4.177
    N190M09P220 (P MUST BE SAME IN 'B' TURRET)
    N200G97S600M03P230 (P AND RPM MUST BE SAME IN 'B' TURRET)
    N210X24.Z20
    N220G14
    N230T0424P180 (P MUST BE SAME AS 'A' TURRET)
    N240M08P190 (P MUST BE SAME AS'A' TURRET)
    N250M42P200 (P AND RPM RANGE MUST BE SAME AS 'A' TURRET)
    N260G97S450M03P210 (P AND RPM MUST BE SAME AS 'A' TURRET)
    N270G0X0.Z5.
    N280Z4.177
    N290G95
    N300G1Z3.577F.004
    N310G0Z4.177
    N320M09P220 (P MUST BE SAME AS 'A' TURRET)
    N330G97S600M03P230 (P AND RPM MUST BE SAME AS 'A' TURRET)
    N340X24.Z20.
    N350M02
    Jul 2003
    126
    I know Okuma's well. Have 8 I program daily.
    If you have a program that is causing issues, you can email it to me at [email protected] and I will help you get through the P issues.
    Be best to just see an issue on your end, and explain what you are doing wrong -vs- trying to explain all the tricks to using them
    Jeff
  1. Sherline spindle to 30k RPM -- am I crazy?
    By nicad in forum Uncategorised MetalWorking Machines
    Last Post: 11-17-2010, 09:57 PM
  2. CNC Controlled Spindle motor speed control
    By gregmary in forum CNC Machine Related Electronics
    Last Post: 02-28-2009, 02:01 AM
  3. Mill spindle repair?
    By kong in forum Uncategorised MetalWorking Machines
    Last Post: 04-02-2005, 07:01 PM
  4. Gilman box spindle pics
    By Swede in forum Benchtop Machines
    Last Post: 03-30-2005, 04:41 PM
  5. 2.2KW Allen Brad. Spindle motor?
    By GalaticDan in forum Servo Motors / Drives
    Last Post: 02-02-2005, 06:46 PM
