586,058 active members*
4,449 visitors online*
Results 1 to 19 of 19
    May 2005
    1810
    Head Tramming question(s)
    When you tram the head, do you typically shoot for perfection, or do you leave a small amount of pitch to compensate for spring, deflection, etc? How much and which direction(s)?
    I recall reading that Bridgeport targeted a small amount of forward (I think) tilt during manufacturing and that is the reason for the question.
    What are the theories/practices?
    Looking for advanced info here, not the basics.
    Thanks!
    Scott
    Jan 2004
    3154
    Perfection definately, IMO if you are cutting heavily enough on a finish cut to worry about head deflection - you need a bigger machine.
    I couldn't possibly imagine a finishing cut with a 1/2" endmill causing any stress/deflection to the head.
    www.integratedmechanical.ca
    Apr 2004
    18
    25 years of experience says perfection, I agree w/ DareBee 100%
    Experience is what you get when you don't get what you want.
    May 2005
    1810
    Thanks for your input!
    Scott
    Mar 2005
    1136
    anything less than perfection is outside of acceptable tolerances - using a tenths indicator of course. You know its right when you get that nice cross hatch pattern with a big fly cutter.
    I don't even want to think about angling the head to compensate for deflection, there are so many variables it would be crazy to do and as others have said not meaningfull or measurable on a finish cut. however the mill head will deflect no matter how light the cut - fly landing on the tailstock affecting the cut and all that
    May 2005
    1810
    I just ran across a pretty nice collection of info on performing this task and I thought I would post it up:
    http://www.sparro.com/KwikByte8.htm
    Scott
    Consistency is a good thing....unless you're consistently an idiot.
    Aug 2005
    1622
    Quote Originally Posted by mxtras
    Scott
    Ha! I Never heard of a 1st WORD indicator! LOL!
    How bout a LAST WORD? And I don't like'm any better than a 1st word if there is one. Too many times the stylus slips or something is screwy. Constantly having to flip the direction lever to reverse the point deflection.
    I'll take a Best Test or a Federal indicator any day over a Starrett! Gem is another Last Word copy that IMHO isn't worth the box they ship them in.
    I wouldn't trust 3 pointing a tramming. Maybe for mills which have only left/right head tilt, but for BP copies and a knuckle joint, 4 point tram is more reliable.
    The troubles I have seen with tramming heads to the tables on old or even hobby mills is that the table is not always true to the way surfaces. Or the way surfaces help tilt the table from severe wear.
    If you use the crosshatch pattern as the true indicator of the head trammed to the ways. Traveling in any direction NO steps should be detectible. If there are, then the table has either shifted or the table surface is not parallel to the ways.
    If the machine will not maintain tram after an axis is moved. Use a fly cutter with a wider swing so the table does not need moved. While that will help produce a flat surface, it will become another pain when setting up for other operations to keep things aligned where tolerances are critical. These mystery shifts in the machine can get frustrating. Setting up a reference, moving 6 inches away to cut another feature, completing the operation flawlessly....only to find the 6" move ended up at 6.03 at the bottom of the part verses 5.990 at the top of the part, rendering it useless from an anticipated level of perfection.
    DC
    Jul 2005
    12177
    You aim for perfection. However, when you do not get there and have to face a large surface and make it look okay you use a small diameter bull end mill. The small diameter means the out of trueness of the table is negligible over the diameter of the cutter and the corner radius on the cutter means the multiple passes blend nicely.
    Aug 2005
    1622
    Quote Originally Posted by Geof
    Normally the head is adjustable, the table is not....you end up at the mercy of the integrity of the ways in relation to the table IF we rely on the table as the true reference.
    For those of us with CNC capability with decent condition machines, this ball nose cutter approach would be reasonable, but manual machine users might not like it too much.
    In my experience, it is tough to do decent surface hem stitch consistant manually. That could leave a bad finish on a flat surface due to the nose of the cutter having no real surface speed, let alone good chip removal. Not all bull nose cutters are created equal. On worn mills, this will reproduce the wear in the ways too. Not to mention the step over to attempt a smooth surface will make the job xxx times longer. If that is all that is available, then by all means, make due. ZZZZZZZZzzzzzzZZZZZZzzzzz!
    If the head were not quite perfectly perpendicular to the table, a fly cutter moving along the least worn axis, should produce the flattest surface the mill is capable of. Even if you must comp the head around to get it to produce a cross hatch. It may not be quite square(which can be compensated for), but I'd expect it should be closer to flat. Things to look for is if the crosshatch comes and goes, or one side of the cutter digs in while moving over a large surface. Determining the cause could be weight shift, loose gibs, way wear or loose spindle bearings.
    With a little ingenuity, anyone can make a bad machine look good.
    DC
    Strange, I always thought if a machinist couldn't tram the head in, they just fly cut the table to match.
    May 2005
    1810
    Quote Originally Posted by StealthDumpKits
    Holy crap! Never - NEVER cut a factory surface unless you are completely restoring the machine.
    (chair)
    Scott
    Feb 2006
    313
    Go ahead and cut factory surfaces if they are rough or out of true. This "never touch" is fine if you are talking about high dollar production machines that *should* be true and accurate to begin with, but it gets silly when you start applying it to IH, HF and similar low/mid hobby machines.
    I had to clean up a booboo on a dovetail surface of my bench mill before I could ever use it. Bit of scrape to fit on a dovetail and then self lap (no abrasive) for all the ways and the machine was good to go. Had I not been willing to recut that surface the machine would have been just another eternal headache; as it was it became a reliable money maker for many years.
    Tiger
    Jul 2005
    12177
    However if you machine the table surface from a head that is not perfectly true and you cut along the X axis all you do is create a concave surface if you use a flycutter that spans the full table width or a whole lot of small concave grooves if you use a smaller cutter. If you cut along the Y axis you simply create a lot of angled steps in the table.
    Feb 2006
    313
    Well sure. As with anything else you can make more trouble than you fix if you don't use some sense and do things right. If you're going to do any cutting, it's pretty much up to you to make sure that cutting is going to do the job.
    Myself, I always kept hardened sweep rings made up for checking spindle/table alignment. A 5" for fast checks and realignments and a 10" for "lets get serious". The things are a pain to make, but if hardened and ground they last forever.
    Tiger
    Jul 2005
    12177
    I was actually responding to this; "Strange, I always thought if a machinist couldn't tram the head in, they just fly cut the table to match."
    Really though I assume this post was intended to stir the pot a little.
    Just an inside joke among maintenance technicians. I've got alot of "WTF!" stories concerning machinists modifying or attempting to repair machines. Leave a Fanuc control parameter manual laying around where they can read it.....
    Jul 2005
    12177
    Just an inside joke among maintenance technicians. .....
    Ah; maintenance techs. Back in my lumber mill days the maintenance techs (they called themselves millrights) were the type of person who, when a sprocket came loose on a drag conveyor would weld it to the shaft, and then leave a note for the Machinist/Fitter to fix it on the weekend shift.
    Yeah, there's alot of backyard mechanics with the title "Maintenance Tech". Back in the day we had electronics techs, electricians, and mechanics or millwrights. Since it was union, a mechanic couldn't do any electrical work, and vice-versa.
    The shop had just finished installing two brand new Mitsubishi vertical turning centers with 6' tables, C-axis and live tools. One went down and our ace mechanic decided the table had to be pulled. Before i got there he already had the 50 ton crane hooked up. I said "you can't lift that table like a regular VTL, it has clamps for the C-axis".
    "No it doesn't, i've done this a million times"
    "Yes it does, I'm telling you don't lift that table! Go get the book if you don't believe me"
    "It's too late for that, i've already got the crane hooked up"
    "Ok, its your call, but I'm getting the hell out of here....."
    Three jogs on the hoist and it broke all the table clamps, sounded like an explosion. The whole thing jumped up two feet and the hooks let loose, then it crashed back onto the base. Was down for three months until the factory could ship new parts an send a rep. The guy never got into any trouble. I was the one who got the blame for not stopping him.
    Jul 2005
    12177
    There are also a lot of green button pushers who style themselves Machinists.
  1. Noise in Bridgeport 2J head (audio file included)
    By daytrader in forum Bridgeport / Hardinge Mills
    Last Post: 08-03-2016, 07:03 PM
  2. Building CNC Surface grinder - whole lotta questions
    By rashid11 in forum Uncategorised MetalWorking Machines
    Last Post: 03-09-2006, 09:53 PM
  3. Some Gecko 201 Questions
    By mikie in forum Gecko Drives
    Last Post: 08-10-2004, 05:40 AM
  4. Full Head Z Conversion
    By IndHobby in forum News Announcements
    Last Post: 03-13-2004, 05:51 AM
  5. BPort Series I and VFD questions
    By NeoMoses in forum Uncategorised MetalWorking Machines
    Last Post: 09-24-2003, 04:47 PM
