586,396 active members*
2,930 visitors online*
Results 1 to 12 of 12
    Mar 2004
    1543
    AMC B100A40AC and shunt
    I bought this drive on the bay:
    http://www.a-m-c.com/download/datasheet/b100a40ac.pdf
    It's for a 10 horse brushed DC spindle on a Matsuura bed mill using a Galil card and Camsoft refit.
    This thing will likely have over voltage issues slowing down. On page two of the manual above, and on the dirve itself, it looks like you can just use a resistor. I have no idea what size.
    AMC also shows these
    http://www.a-m-c.com/download/datasheet/srst.pdf
    Are these necessary for this use?
    Karl
    24223
    They already have internal shunt switching circuit, and a 20ohm resistor, the rating of the internal resistor is 180watts.
    If there is repetitive high speed braking then you may need to fit an external one of the same ohms value but higher wattage rating.
    The regulator comes in at a bus voltage of 390dc
    Al.
    Albert E.
    Mar 2004
    1543
    Thanks, I'll start shopping. I assume the internal one must be disconnected? How?
    24223
    Page 2 remove the jumper between 2 & 3.
    Al.
    Albert E.
    Mar 2004
    1543
    Thanks Al, i should have seen that.
    Say, how close to 20 do i need to be? here's this eBay offer:
    http://cgi.ebay.com/IPC-Power-Resist...item3ef0b63fd9
    Karl
    24223
    At 22ohms should be close enough, you can even shorten one winding if you had to.
    Al.
    Albert E.
    Sep 2007
    77
    Did you get two of them? I was watching an auction of two of those drives on Ebay sometime back around when you made this posting but didn't bid. I was hoping to see the 2nd one go back on Ebay. I'm still looking for one.
    Quote Originally Posted by Karl_T View Post
    Karl
    24223
    The last lot I snagged were a lot of 3 for $200.00, I was the only bidder!
    Al.
    Albert E.
    Sep 2007
    77
    Want to sell one? I've got both a 10s and 20s and a pico fanuc encoder board already while I wait for a good deal on a drive to pop up on ebay. If I get a b100a40ac I aught to be able to go with the 20s (want to replace the ge pancake motor and varispeed on my spindle wizard excello with a servo).
    I'm about to move so I'm in no rush but if I can get a deal I'll get it.
    Al.
    24223
    They all happen to have gone on projects.
    I used a 5S with a B40A20 on the spindle on a 9x30 lathe that worked out OK, I replaced the encoder with a Renco in my case.
    I have yet to try it out as a C axis, although it should be capable.
    Al.
    Albert E.
    Sep 2007
    77
    Do you know what control people are using with the s series drives? Not that I'm going to change controls now, I've just become curious after seeing big s series drives listed constantly.
    24223
    They can be used by the likes of Galil. The down side is that each two sinusoidal outputs for one drive use up two axis output designations.
    AFA the drive design, they are the simplest to make, minimum components.
    Al.
    Albert E.
  1. Shunt circuit
    By fahque99 in forum CNC Machine Related Electronics
    Last Post: 08-05-2009, 05:54 AM
  2. R Shunt Burn
    By wanchai101 in forum Servo Motors / Drives
    Last Post: 03-26-2007, 04:20 PM
