We have 9 SS machines where I work. I'm curious how hard people are pushing these machines. We do mostly aluminum work with some stainless and the occasional small inconel or titanium job. On some of our aluminum jobs where we have a lot of 3D roughing we'll push them harder than some might think is acceptable but I'm not all that convinced it's inappropriate. In particular one job uses a 1/2 inch 3 flt roughing carbide tool 12000 rpm full slot at approximately .1 axial depth of cut at 600 ipm. Initial perimeter roughing is approximately .5 axial deep and .2 radial depth at 800 ipm. With fresh coolant there's no shrieking of the tool at any point. Certain points around the perimeter will reach 130% spindle load momentarily and during the rest at 600 ipm it typically doesn't exceed 50-60%. The machine sounds fairly smooth. The cut sounds typical of the tool at slower feedrates, but louder because of the high feed rate. In other words, nothing seems to be overworked including the axis loads.
To be fair, during the 600 ipm cycle it propably doesn't get up that fast because of the cornering, etc. However during the 800 ipm cycle I'm sure it achieves at least most of the speed there.
What are others doing with these machines? With a top feedrate of 833 ipm how many of you are pushing them this far? The spindle's designed to run at 12k rpm and that's where ours spend most of their time. What are your opinions/typical use of these machines. It should be noted that these are production machines in a job shop.
I ask this because the machine that is running this job currently, just went down last week because the spindle motor bearings sh*t the bed. Now some are up in arms suggesting that this job is the cause. We've had other motors fail in the exact same way including machines that never get pushed that hard. Seems to maybe be a typical failure for this motor. The spindle is perfectly fine, in fact the machine went down this past Friday and the motor was pulled, bearings replaced, reinstalled and the machine was back up running this morning. The axis are still accurate (the parts are good at least). I would expect to see spindle damage or axis damage from hard running like this before motor failure.
Greg
