586,117 active members*
3,505 visitors online*
    Aug 2007
    26
    SX3 to SX4 conversion
    I have recieved my kit but without instructions. I have viewed the other recent posts on the subject and checked out the SX4 manual online. Unfortunately my spindle controller board is a different version from those online. I wonder if anyone has used this newer board and can help me identify the connections required (if any) at sites 1 to 9.
    Version on board is A01 091224
Name:	Syil Spindle Controller X4 Rev A01 091224.jpg
    Mar 2006
    43
    my board is a different version, but here is some help:
    1 or 2: E stop....no idea which is which
    3 or 4: E stop output to BOB
    5: spindle control to your 5 axis BOB
    6: no idea
    7: no idea
    8: not used
    9: not used
    The two pin connector on the main board in the bottom RH corner should be for the spindle auto/manual switch...and I'm guessing there is a connector hidden by the daughter board in this picture....that is for the Hall effect sensors in the motor
    Sorry...I thought I could help more....
    Aug 2007
    26
    Thanks for your reply.
    The two pin connector bottom right is labelled K1 K2 and is shorted out.
    There is a 5 pin connector hidden under the daughter board and it it matches the markings on the secondary cable from the new spindle motor.
    The "manual/cnc" control for the spindle has been separated out and I presume goes to either 1 or 2.
    Maybe there is someone with a new SX4 that could have a look in the back.
    Mar 2006
    43
    what you have going on is pretty much the same as what I have.... although the boards are configured quite differently.....
    K1 and K2 are shorted to bypass the manual/auto switch (mine is not shorted, but runs to the front cover switch)
    the larger green 5 pin connector is for the secondary cable (the hall effect sensors)
    The E Stop is almost guaranteed to be going to either 1 or 2.
  1. Another X2 CNC Conversion (yay!)
    By skmetal7 in forum Benchtop Machines
    Last Post: 02-01-2010, 09:47 PM
  2. servo conversion vs stepper conversion
    By contractdesign in forum Bridgeport / Hardinge Mills
    Last Post: 07-26-2008, 08:54 PM
