586,061 active members*
4,694 visitors online*
IndustryArena Forum > CAM Software > UG NX > Converting a pdf file to UG part file
    May 2010
    Hi all, i need help in converting a pdf file to a UG part file
    I'm using NX5 for drawing.
    Is there any software that i can convert it ??
    Thanks for viewing.
    Mods,if it is in the wrong section, please kindly move it to the correct section
    TIA !!
    May 2010
    YES you can have software PDF to DXF
    WHERE YOU MATTER TO GENERATE AND DXF NX and converts it into 3D
    HUG
    ANDRÉ LUIS DO NASCIMENTO
    SPECIALIST CAM APPLICATIONS MULTI AXIS / IS&V (NX)
  1. Replies: 8
    Last Post: 05-04-2015, 12:49 PM
  2. converting a mastercam 9 file into a Solidworks file
    By Michael82 in forum Solidworks
    Last Post: 04-17-2009, 07:14 PM
  3. Help converting .fgc file
    By slammedxonair in forum DynaTorch
    Last Post: 02-12-2009, 10:19 PM
  4. Replies: 3
    Last Post: 12-11-2008, 02:45 PM
  5. Converting ACAD DWG into Inventor Part file
    By phil m in forum Autodesk
    Last Post: 11-21-2007, 07:03 PM
