586,540 active members*
2,933 visitors online*
    Sep 2005
    5
    X1 CNC Capabilities
    Hi Everyone,
    I've had an X1 collecting dust for a few years and have recently thought about converting it to CNC. I have a few questions that I hope someone can answer to help decide if it's worth it.
    1. The parts I want to make are 2x2x5" aluminum. One side has a 1.75x2" pocket at a depth of 1-7/8". Would this machine be able to handle that or would I be exceeding the limitations of the X1?
    2. Probotix has a control kit for $199 with 166oz motors. Would that be enough or do I need more powerful ones? I've also seen the kits at Keliginc.com but they are closer to $400.
    Thanks!
    Oct 2009
    446
    I havent CNCed mine yet and im not sure if I will. But from what ive read 166oz motors are allitle on the light side especially on the Z axis.
    I machine plenty of stuff with my X1 . The only problem I seen was the motor was gutless.
    Everything was machined very slowly in light passes.
    It wont have a problem machining aluminum. you should be fine.
    Aug 2009
    899
    I have used the Probotix Monster Kit for my X2 and loved the hardware they supplied. The boards are built well and very easy to wire up. If you give them a call they will have problem helping you with making sure you get what you need. They would probably be able to sell you a kit with 2 166oz motors and 1 260oz for your Z-Axis. In the end the kit would work well for what you are wanting and I suggest it as you wont have to spend $1000 only on electronics.
    These drivers do no offer Mid-band resonance damping but I do not really seeing you needing this on an X1.
    I would suggest picking up another E-stop button to.
    Mar 2005
    335
    i have converted my x1 about 3 -4 years. i have used for many projects. machining ally brass, little steel and carbon fiber and pcb. My machine is heavily modified,
    6000 rpm belt drive conversion and ball screw on the z and secondary high speed spindle for pcb and fiber work. z axis is also counterweighted which i think is a must for smooth running with light steppers.
    Axis wise i started with a hobby cnc 200oz setup unipolar. this worked well but rapids were slow and 300mm/min. z was unreliable if it was pintched up. I then went to a bipolar setup using the same unipolar motors raising the torque to about 280 this was to make it into a peach. i also changed the z axis motor to a 400 oz which really improved the performance.
    in ally i can cut 1.5mm on a 10mm cutter at 6000rpm feeding 200mm/min you can work out how long it is going to take to hog out your pocket.
    check out my project page
    http://revdesign.co.uk/BeltDrive.html
  1. General question about the TM1-P capabilities.
    By l u k e in forum Haas Mills
    Last Post: 04-06-2009, 10:23 PM
  2. Boss-8 capabilities
    By RP Designs in forum Bridgeport / Hardinge Mills
    Last Post: 04-05-2009, 06:55 PM
  3. Router capabilities?
    By paul_l in forum DIY CNC Router Table Machines
    Last Post: 08-09-2007, 01:02 PM
  4. question about it's capabilities
    By Twin-X in forum Commercial CNC Wood Routers
    Last Post: 01-24-2007, 03:53 AM
  5. Makino capabilities + 6MB
    By steedspeed in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-15-2006, 05:14 AM
