586,584 active members*
2,600 visitors online*
Results 1 to 8 of 8
    May 2010
    Simulation Control Panel not displayed
    I have a problem with solidcam simulation. Firstly simulation control panel ( ) worked well, but now when I click "Calculate & Save" and then "Simulate" Simulation control panel is not displayed and I cant do right click on anything in SolidCAM manager (tree with... cam-par, tool, geometries, operations)... also can not close (by clicking on X) opened solidcam part (only solidworks directly). I thing that is because of Simulation is still opened but I can't see it. When restart solidworks and open solidcam part then right click in Solidcam manager is available until I click on "Simulation" in any operation again. I tried to open another solidcam part but the same problem. I was using touchpad and maybe I disabled simulation control panel by mistake (bad click or move something).
    Any help would be great.
    I am using solidworks 2010 and solidcam 2008R12. Win XP SP3.
    Dec 2007
    12
    Quote Originally Posted by mike256 View Post
    SolidCAM2008R12 does not support SW2010.You must use SC2009SP4 or highest version of SolidCAM for SW2010.
    May 2010
    thanks for answer.
    Simulation control panel was working well for several days (althought I was using Solidcam 2008) and now I can't see it. Now, I have installed SolidCAM 2010 but the same problem. I tried to reinstall solidworks but no success.
    Any idea?
    Sep 2013
    5
    Hi! Did you find any solution?
    It happened to me to... I deliberately closed the simulation panel with the "x" from top right, and after that it was happening what you say.
    I have tried hard to find some setting but I didn't find.
    I even reinstalled both SolidCAM and SolidWorks and ... nothing.
    Mar 2013
    12
    mike256
    We have had a lot of Solidcam problem go away when we got the correct SolidWorks video drivers off the SolidWorks web site. Try that.
    Nov 2010
    7
    Re: Simulation Control Panel not displayed
    Anyone found a solution to this? I've tried removing recent updates, different video drivers, reinstalling solidcam
    Windows 7, Solidworks 2014 x64 SP1, Solidcam 2014 x64 SP2
    Andrew
    Nov 2010
    7
    Ok I got it
    1. Open the registry editor.
    2. The string your looking for is \HKEY_CURRENT_USER\Software\SolidCAM\SolidCAM2014\ Simulation\Windows Positions\SimManager
    3. This is what your data should look like
    Resolution = 0x03200500 (52430080)
    WndPlacementStruct = *3*1*-1*-1*-1*-1*218*145*457*497
    WndPlStruct_StrLenght = 0x00000033 (51)
    Most likely the last 4 numbers in WndPlacementStruct entry will be in the thousands just change these back to something like I have shown.
    ****DISCLAIMER*****
    No responsibility if something goes wrong from this advice.
    Jul 2015
    14
    Quote Originally Posted by Snarfty View Post
    Ok I got it
    ****DISCLAIMER*****
    YOU ARE ABSOLUTELY AWESOME!!!!!!! thank you so much!!!!!!!!!
  1. Replies: 10
    Last Post: 06-07-2014, 06:12 AM
  2. Replies: 1
    Last Post: 02-19-2014, 02:19 AM
  3. CL 203 CONTROL PANEL
    By gtrrpa in forum Mori Seiki lathes
    Last Post: 04-22-2011, 08:15 PM
  4. Control Panel Cut out
    By scruffyjones48 in forum Employment Opportunity
    Last Post: 08-03-2008, 09:47 PM
  5. My DIY control panel
    By DennisCNC in forum Community Club House
    Last Post: 10-03-2006, 04:24 AM
