Has anyone seen this?
About once every couple of weeks our VF-2ss won't see the program on the flash drive. It will only see the (deleted) one that was loaded just before.
On my computer, with the flash drive in the USB port, I will delete the old program then load a new one with a different name onto the flash drive.
Safely remove it, then insert it into the Haas USB port. List program and select USB device. Only the deleted program shows up. If I select it and load it anyway (hoping it was just a name issue), the old program shows up.
The only way I've found to fix this issue is to turn off the Haas and restart. Then it sees the new program.
What the heck, over.
Not a big deal but curious.
