586,082 active members*
3,533 visitors online*
    Sep 2006
    24
    Tool offset limits
    The machine is a LB-15 lathe with OSP-5020L control with user task 2. Currently, the offset values are in the header lines of the program and the operators type them in before running the first part. Too many times they either type a wrong number, add a - sign or just fat finger the keys and crash the machine. I'm going to keep the offset values as close to 0 as possible and I am going to change the zero set for each tool with VZOFX and VZOFZ after it is called up. Since the edit lock is always on, they can't change the values. What I want to do is limit the value in the tool offsets so the operator can't put in too large or small of a value, say + / - 1mm just to account for tool wear. I want to make this as idiot proof as possible.
    Feb 2009
    6028
    I would assume you have pre-set quick change tooling on the machine, otherwise you don't need to re-set the tools for each job, just zero set. You can also download tool offsets and put them back in via RS232 with the program.
    Aug 2008
    62
    Number 33 under optional parameter long word limits the amount of offset addition/subtraction. Initial setting is 1000 which would be (.1000). Changing this number to say 50 would be (.005). This doesn't limit the amount of times an operator can add/subtract from the offset though. Just the amount of movement each time the offset is changed.
    You might want to actually set limits on the offsets so that the machine alarms out if these limits are exceeded.
    IF [VTOFX [3] LT 1.3600] NALM1
    IF [VTOFX [3] GT 1.3750] NALM2
    IF [VTOFZ [3] LT .3450] NALM3
    IF [VTOFZ [3] GT .3550] NALM4
    G50S300
    G0G95G97X50.Z50.S50T0303M41M3
    program
    M1
    This is limiting offset #3 in X and Z. If offset #3 does not fall in the limits you set, the machine will alarm out and not run.
    Hope this helps,
    Rick
    Mar 2009
    1982
    I agree with underthetire. It's too many oportunities for operator to make a fatal mistake.
    a tool offsets must be changed when tool insert is changed. It in not associated with part in most cases. So the normal ways are:
    1. saving into file and using tool set as parameter branch
    2. saving into file and using tool set as variables definition in part program
    ... via RS232 with the program ...
    Sure, the *.TOP file or set of variables definition could be stored directly in user disk (MD1: ) for easy access. It's better to save the copy on the PC, of course.
    There is variable VXMCD named "offset amount". Maybe?
  1. Changing tool diameter in the tool offset screen
    By Vern Smith in forum Haas Mills
    Last Post: 05-09-2022, 05:25 PM
  2. set up tool length offset and ref tool on mill
    By buklattt in forum CNC Machining Centers
    Last Post: 04-01-2012, 05:01 PM
  3. Renishaw tool offset / break probe and tool life management
    By mcash3000 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-21-2010, 04:14 AM
  4. Offset, measure the first tool and second tool
    By domax in forum Daewoo/Doosan
    Last Post: 12-30-2009, 05:20 AM
  5. Tool Axis limits
    By kojack in forum Mastercam
    Last Post: 06-12-2009, 08:03 PM
