First, here's the basics of what I need:
Double-sided PCB 8x12 (possibly smaller) with traces milled, and holes drilled out. Quantity 2.
I would like a rough quote for work done. Also if you provide the board, how much for the boards?
Now, for my other questions. Since this is the first time I'm asking for CNC work... What file format is needed to make this as easy as possible? And what program is recommended? I have autocad 2000. I can export anything to pdf.
This is to run the CNC machine I'm building.
