586,110 active members*
3,181 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > RETROFIT OF RADIAL DRILL MACHINE INTO CNC MILL
Page 1 of 3 123
Results 1 to 20 of 59
    Apr 2006
    3498
    This is first time i am working on CNC retrofit of a Radial Drill Machine. The existing machine is manufactured by Pakistan Machine tool Factory with a working area of 340x 340mm. Presently, the machine is under major retrofit with latest 3-axes CNC Control System. The controller will be able to do 2D and 3D contouring of complex shapes with higher accuracy, less resources and less time.
    This retrofit will help us making complex parts for fabrication of 10ft x 10ft CNC Milling machine.
    SCREW REPLACEMENT
    Currently the Machine has ACME screws at X/Y cross slides. To get optimum accuracy and low-backlash these ACME screws will be replaced with Ball screws.
    CUTTING FLUID CONSOLE
    For High speed machining cutting fluid is abundantly required on the work piece. New Console was fabricated using in-house facility. The pump will be controlled with the help of computer M-code command.
    CROSS-SLIDES
    Cleaning of linear ways and minor modifications for ball screw installation is underway.
    STEPPER MOTOR PULLYS
    The machine will be driven with stepper motor. These stepper motors will be installed on X-Y Cross-slides and Spindle (Z-axis). Stepper motor pulleys with 3:1 reduction has been machined.
    SPINDLE OVERHAULING
    The spindle of this machine can carry tools up to 13mm diameter. The ranges of the spindle RPM is from 251~ 2560. The spindle is driven with 3-phase 2.2hp motor. Spindle gears and internals are currently being overhauled. One of the roller bearing was replaced due to high noise and clearances. We have minor backlash in the collet-shaft rack-pinion gears However; this backlash may be compensated in the controller software.
    I hope you will enjoy the thread and comments...
    Attached Thumbnails Attached Thumbnails Machine original.JPG   Machine.JPG   spares.JPG   SpindleOpen.JPG
    http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/
    http://my-diysolarwind.blogspot.com/
    Apr 2006
    3498
    Some more advancements
    Installed the counter weight on the Quill.. Have ready X/Y carriage for stepper mounts.. A little work on enclosure today...
    Attached Thumbnails Attached Thumbnails DSC05096.JPG   DSC05095.JPG   DSC05094.JPG   DSC05100.JPG
    Apr 2006
    3498
    I have installed stepper Motors and calibrated the slides.. I am getting 0.4mm backlash at X-axis (The bottom carriage) and 0.17mm at the top carriage.. After backlash compensation I am getting 0.02mm tolerance at the bottom carriage and 0.001mm at the top carriage...
    I am really very happy with the results... The above tolerance values were checked within 10mm of screw travel.. I will check the Precision/Foot of the carriage tomorrow..
    However, I have checked by travelling back and forth several time and my values are consistent within the above mentioned range...
    Feb 2007
    191
    Hi Khalid, Nice work.
    Congratulations.
    Regards
    Rene
    Apr 2006
    3498
    Hi Rene,
    thanks...
    Currently I am getting problems in calibrating the Z-axes... When I using Mach3 to setup it in 'MM' metric unit..I am getting 12.344 steps/mm... This is very course I don't know why?
    My Motor is = 200 steps
    Gear Reduction 3: 1
    I am using 1/2 step mode...
    I don't know what is driving the quill but it is something Rack and pinion, i don't know the specification..
    so the mathshould be simple...
    200 x 2 x 3 x Y= 1200 x Y.
    but Mach3 only returning me 12.33 steps!!!!!
    What should i do?
    Feb 2007
    191
    Hi Khalid
    Attach a table.
    Hope this helps you.
    Let me know
    Regards
    Rene
    PD-I was been very busy, I want to finish embroidery structure soon as possibler, next week weekend arrives new cnc controller for diy embroidery machine and a singer embroidery press foot.
    Attached Files Attached Files
    Apr 2006
    3498
    Thanks REne..
    I am checking the spreadsheet... If I am getting 12.74steps/mm then what resolution i can achieve on Z-axis?
    Nice to hear about the controller and embroidery machine..Currently I abandoned the software project.. You keep working on it..When your research completed i will ammend in embroidery software...
    Feb 2007
    191
    Hi Khalid
    As I understand, resolution is a movement than we can get
    In one step, in this way your resolution will be
    = 1step / 12.74step/mm =0.078mm
    Tell me if this is wrong.
    Regards
    Rene
    Apr 2006
    3498
    Here i want to show the completed machine with failed attempt of drilling in Carbon steel plate.. I am getting very less torque due to coarse ratio of gearing.. I am going to install Worm-Wheel arrangment on Z-axis soon..
    Attached Thumbnails Attached Thumbnails Cross slides.jpg   DSC05127.jpg   DSC05128.jpg   DSC05131.jpg
    Feb 2007
    191
    Hi Khalid
    Nice project.
    What kind of steppers are you using?
    Some day I want to do like you with my drill press
    I need a 48 hours day.
    Regards
    Rene
    Apr 2006
    3498
    Hi Rene, I am using NEMA34 1200 Oz-in (Bipolar mode)stepper...but i am using these stepper in Unipolar mode so getting aroung 750 Oz-in torque... Yesterday I removed the Automatic Feed gearing and now with one revolution i am getting 0.0016mm Feed
    and with a lot of torque...
    Feb 2007
    191
    Smile
    Hi Khalid
    This is a lot of torque!! Now you can mill a lot of pieces for future projects
    including a small pieces for embroidery project,, sorry we are living at very long distance.
    Congratullations for this good and almost concluded project.
    Seriously asking,,, do you think to come back to embroidery project?
    Iam not refering only about promised update of software, also I'm refering to finish your own embroidery machine, and after, work for change to continuous running motor, and make all improvements as possible. Iam working a lot reading, investigating and writing an algoritm for running continuos motor and asking a lot in Mach forum,ecc.
    I recopiled, optical switches, small stepper motors, belts,solenoid, buy a new CNC controller and a mini DC relay for motor and solenoid control.
    I know that you are involved in a multipled projects, and this make me happy, you are a big inspiration about all is possible to do using small resourses,( 4th axis, laser scanner, ecc).
    For my part I don't have promgramation knowledge, but I can use my time for continuing bulding embroidery machine, testing new components, and work methods. Then I can make new sugestions for do the best in project.
    Regards
    Rene
    Apr 2006
    3498
    Rene...My embroidery project is abandoned for the time being.. However, once your research completed i will ammend in embroidery programm... I will surely help you so that atleast you can work on your embroidery machine...
    Just complete your research and i will try to programm for you.. if i remain alive..
    PS:
    Actually i am involved in making a huge CNC drilling machine...so i have less time for other projects..
    Apr 2006
    3498
    yesterday, i made some progress.. Following are the mock-up results of tube sheet drilling for one of our exchanger..
    Program used:
    1-AutoCad
    2-VisualMill 5
    3-Mach3
    The feed was calculated for
    1- Dormer centre drill A-201 HSS
    2- Spindle RPM: 800
    3- Cut feed: 215mm/min
    Total holes: 220 Ea
    Time :52Minutes
    Attached Thumbnails Attached Thumbnails DSC05133.JPG   DSC05136.JPG   DSC05140.JPG   tolpath.jpg
    Feb 2007
    191
    Very nice.
    Interchanger is a fluid interchanger in fertilizer plant?
    In Art Cam you can draw easily too this circular holes grid
    Regards
    Rene
    Apr 2006
    3498
    hi Rene,
    Yes Interchanger or Heatexchanger is a cooling unit used in fertiliser plant...
    No problem with the Artcam.. but our Engineering Unit make the drawings in AutoCAD and gave us for manual drilling..This time i got the SOft copy of the drawing and let it into VisualMill.. Visualmill is a powerful software for Milling/Drilling in Steel.. It has various options as Artcam don't have...
    So I enjoyed both the softwares for different purposes..
    Apr 2006
    3498
    Started building new Spindle and its houseing.. The Spindle is off AISI 4140 hardened to 55HRC... and now it require grinding... The Vertical column is also in fabrication phase.. I will get red of complete Radial drill except the Cross-slides..
    The New column is very sturdy..
    Today i did some drilling on 30mm SS316 Plate using 8mm HSCO drill..
    Attached Thumbnails Attached Thumbnails Column.JPG   Housing spindle.JPG   Rails.JPG   Spindle.JPG
    Apr 2006
    3498
    Hi
    Today I finished the tube sheet drilling with final hole size 9.5mm..
    I Gcoded to stop the machine after each 5 holes to remove the swarf around the drill bit... Following was my strategy..
    Spindle RPM: 400 RPM
    Feed: 3 IPM
    Peck Cycle: G73 with 3mm per peck
    Time to complete One hole: 1minute 5 seconds
    I drilled all the holes within 5Hours.. You can see the video in the following youtube link..
    [nomedia="http://www.youtube.com/watch?v=FH2X_W2MHBY"]YouTube- CNC Drilling Holes[/nomedia]
    Feb 2007
    191
    Khalid.
    Very nice work, congratulations.
    Finish holes quality seems to be perfect.
    Regards
    Rene
    Apr 2006
    3498
    I have machined the column and now ready to drill holes for linear Rails..I machined exact slots for the width of linear rail on a NC boring machine... The base and the column are perfect at 90 degree...
    Meanwhile, the spindle grinding is now in action after hardning upto 55HRC...
    Attached Thumbnails Attached Thumbnails spindle grinding.jpg   spindle housing.jpg   column.jpg   column2.jpg
Page 1 of 3 123
  1. Direct Drive Vs Belt Drive for a Mill/Drill Retrofit?
    By pfeist in forum Uncategorised MetalWorking Machines
    Last Post: 02-13-2012, 09:12 AM
  2. Anyone in the East Tennessee area doing a mill drill retrofit.....
    By pete from TN in forum Benchtop Machines
    Last Post: 05-04-2008, 02:00 PM
  3. Yoshida Radial Arm Drill Press
    By jnsane84 in forum Uncategorised MetalWorking Machines
    Last Post: 02-07-2008, 08:31 PM
  4. Where to begin? Retrofit a Stepper Control to a Mill-Drill?
    Last Post: 05-04-2004, 11:44 PM
  5. CNC retrofit for Mill/drill?
    By Jkier in forum Uncategorised MetalWorking Machines
    Last Post: 07-04-2003, 12:42 AM
