586,108 active members*
3,293 visitors online*
    Mar 2008
    161
    Yaskawa bob for Kanalog
    I've been amassing parts for a while now and finally am ready to start putting things together.
    I will be running some Yaskawa SGDH drives with a Kanalog controller. I want to make myself a breakout board to interface the CN1 i/o with the kanalog and have the limit switches talk to both.
    Some features of the board I want to incorporate are:
    Set speed reference voltage on bob
    Input for limit switches, which will talk to drive and controller
    Alarm output to controller and other drives
    External kill switch to drives
    I am not using absolute encoders so I wont have any battery back-up on the bob.
    I also don't plan on using any torque reference voltage on the bob. I am not sure if this may come in handy later, but for now I plan on leaving this out unless convinced otherwise.
    Any suggestions?
    Mar 2008
    161
    ..build isn't dead, life just got in the way for a bit.
    Got my manuals printed up at least in the meantime.
    Feb 2004
    83
    Oxford
    Looking forward to your posts since I want to use the same Yaskawa SGDH drives with a Kanalog / Dynomtion controller.
    Jack
    Mar 2008
    161
    gathering parts for testing
    So far I will limit the I/O for the SGDH to the following twisted pairs:
    V-REF SG Velocity control
    T-REF SG Connect with resistor circuit to have torque limit option
    ALM+ ALM Safety kill
    S-RDY+ SRDY Safety
    PAO /PAO -Encoders
    PBO /PBO
    PCO /PCO
    /S-ON +24V -For safety
    P-CON +24V -Have option to switch between P and PI if needed
    P-OT +24V -Positive over limit switch
    N-OT +24V -Negative over limit switch
    /ALRM-RST +24V -Reset servo drives after emergency stop
    /P-CL +24V -Positive current (torque) limit
    /N-CL +24V -Negative current (torque) limit
    One of the next steps now is to interface all the I/O with the Kanalog.
    With the limit switches, I want to wire them to kill the drives as well as cause the software emergency stop. I had an experience in the past where the limit switches failed because they were only wired to cause an emergency stop through the computer software and the computer froze...resulting in a scary moment and a crushed limit switch:P
  1. yaskawa
    By outctrl in forum Servo Motors / Drives
    Last Post: 09-16-2009, 02:05 AM
  2. Yaskawa Sigma II
    By wrloveyuelin in forum Machines running Mach Software
    Last Post: 07-02-2009, 06:24 AM
  3. Yaskawa Varispeed 626 MT
    By bradodarb in forum Phase Converters
    Last Post: 04-27-2009, 02:38 PM
  4. Yaskawa help please
    By Arty 3000 in forum Stepper Motors / Drives
    Last Post: 02-20-2007, 05:35 PM
  5. yaskawa help please
    By h_2_o in forum Servo Motors / Drives
    Last Post: 11-20-2006, 02:01 AM
